abit off center
cgarr's Avatar
Fixing a radon problem
anyone have high radon levels in your house? Finished basement so we really cant go back and seal the concrete. How do the vent systems work where you draw a vacuum under the slab work? Any good ideas? Levels are twice the high rate:
______________________
Craig
G2Performance
Old 08-08-2016, 12:09 PM
wdfifteen's Avatar
My wife had to have one of these negative pressure systems installed when she bought her house using FHA. It seems to work. Subsequent tests always showed levels in the basement below the limit.
Radon Mitigation - SYSTEM DESIGN BASICS
Old 08-08-2016, 12:12 PM
abit off center
cgarr's Avatar
Thats the system I was looking at but this link explains it good! Thanks
Craig
G2Performance
Old 08-08-2016, 12:26 PM
wdfifteen's Avatar
I should add that her house had water intrusion through the basement walls (walls are not airtight) and a sump that is not sealed. The system still kept the radon levels under the maximum.
Old 08-08-2016, 01:19 PM
MBAtarga's Avatar
Our house (bought 4 years ago) has a system installed from the previous owners/builders.
Draws air from 1 pipe under the 3 car garage slab via basement wall access, and another pipe under the basement slab itself. It runs 24 hrs/day - 365 days a year. Each vented area is backfilled with gravel to allow "air" space.
Mark
'83 SC Targa - since 5/5/2001
Old 08-08-2016, 07:37 PM
Regenerated User
72doug2,2S's Avatar
Easy to reduce crazy high levels, hard to reduce low levels.
What is your level?
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 08-08-2016, 08:00 PM
