Thumbs up 2000chevymalibuLs Help from best mechanic
I have a 2000 Chevy Malibu LS that won't start it slow cranks.Still the engine doesn't turn over. Have an obdll scanner and was sent a po107 code.The codes for a map sensor/barometric something.Need help from the best mechanic!The valves inside the engine don't crank I looked thru the oil cap and the valves were exposed. I had some one crank the car while looking they didn't even budge.The car also sounds as something turningNeed the help
Old 12-30-2016, 06:55 AM
Gary H 1978 911 SC
You say a 2000 Chevy Malibu.......Let me Google that for you.
Gary H 1978 911 SC
Old 12-30-2016, 10:30 AM
The Unsettler
stomachmonkey's Avatar
1st post on a Porsche enthusiast board and he's asking about a Malibu with possible blown timing chain?
I have never, ever, in all my time here put anyone on ignore.
This might be a first.
"I want my two dollars"
"Brandon Won"
Old 12-30-2016, 10:37 AM
slow cranks..but won't turn over???
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 12-30-2016, 10:51 AM
Arizona_928's Avatar
Just fill the trunk with tannerite and leave it in Chicago. I'm sure you'll get one last movement "under its own power"...
dolor et pavor
Copyright
Old 12-30-2016, 10:54 AM
I have sinned!
gorthar's Avatar
Hey, hey! He only wants help from the best mechanic!
Old 12-30-2016, 11:52 AM
Fight to the death until the best mechanic is crowned. Lol
dolor et pavor
Copyright
Old 12-30-2016, 12:39 PM
Weird. Seems like a troll.
https://tr.poshmark.com/closet/rajari5707
Valves aren't moving, but the engine is "cranking" (but not turning over), then that would point to a timing belt issue, except that it's a 3.1L V-6, so a timing chain. Still, those can go bad.
I think it just needs to be pushed to the nearest junkyard.
Old 12-30-2016, 01:31 PM
Preferred pronoun:Maestro
Norm K's Avatar
I think what he really needs is advice and opinions as to which is the best oil for his air-cooled Malibu.
_
When in doubt, use overwhelming force.
Old 12-30-2016, 01:39 PM
fastfredracing's Avatar
No left turn un stoned
Old 12-30-2016, 01:41 PM
Non Compos Mentis
It's obvious the primulator is toast. Common problem with a Malibu.
While you're at it, replace the pfitzer valve. When they go bad, the first indication is when the primulator goes out.
Old 12-30-2016, 02:12 PM
Right, and when the pfitzer valve goes out, the car cranks really slowly, but then when the primulator is gone, it won't turn over, good call.
Old 12-30-2016, 02:46 PM
