Gary H 1978 911 SC
Aircraft Maintance O300D C170
OK so my last annual in August I had 1 Cylinder with low compression and last week maximum RPM was slightly over 2000 so no flying. Compression test showed #4 with a stuck exhaust valve wide open. So we have to pull #4 and the #2 was the cylinder with the low compression in August so we pull both and I drive both to a cylinder shop 30 minutes away. The shop grinds all 4 valves, installs 2 new exhaust valves and valve guides and only takes 1 hour and I am out the door .....Get This for only $180 with yellow tags. My A&P and I reinstall every thing and now all 6 cylinders have over 65/ 80 cold @ 35 degrees. I paid the A&PAI $550 and now it flies great again for only $730 and I could not be happier. What would that have cost on an 911 SC?
Gary H 1978 911 SC |
Senior Advisor
A lot more!!!! thats great about the cylinder shop close by. I'm an A&P and thinking new parts for 2 cylinders and misc. parts, around $1800 for parts and $1000 labor (1 person) so yeah, thats a great deal. O-300's are super smooth running and use a lot of O-200 parts so relatively cheap.
08 Cayenne Turbo |
Bland
The 911 engine is a different bird because they are overhead cam. There are a lot more parts in the way to get the heads off. Then you gotta set the cam timing, etc when you reassemble. Not an afternoon job...
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Senior Member
Gary,
I am in the middle of overhauling three C-145/O-300's right now and know the feeling! Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Non Compos Mentis
A while back Continental started using high-tech machining processes in their factory that was to have tolerances so tight that they could grab any head, valve, guide and seat and assemble them without any hand fitting. Exhaust valves wearing prematurely have been common ever since. |
Gary H 1978 911 SC
Possibly the best part the plane was down for less than 24 hours. When it first happened I figured 2 weeks down.
Gary H 1978 911 SC Last edited by gshase; 01-12-2017 at 05:04 PM.. |
I've thought many times while owning two old Porsches I could easily afford a Cessna single for the same money. Hanger would be pricey, though.
Kurt |
Curious question: Is it now easier to find qualified Continental engine mechanics than it is to find good air-cooled Porsche mechanics?
Gary H 1978 911 SC
At my airport and around DFW there are a good number of Continental engine A&Ps.......Harder to find an A&PI
Senior Member
Kurt,
The hangar is a killer in some areas. Friend of mine left his airplane in Phoenix after he moved to SoCal. Hangar there was $2000 a month... here $200. Fan, The older continentals are 1930's design, not hard to work on. Gary, The old timers are all retiring or passing. Thats why I got my IA a while back as very few these days understand dope and fabric airplanes.
^^ Two hundred dollars is actually pretty cheap for a hanger but places like Deer Valley won't let you put a car in the hanger, even when you have your plane out and flying.
Kurt |
Senior Member
Sorry but yes they will... We do it all the time and its written in the bylaws.
Well that's good news. Either something had changed from several years ago or I mis-heard.
Kurt |
I am in Orange County California and hangar at Chino for $250 per month. I have no issues with storing and keeping cars there.
Non Compos Mentis
The FAA recently revised, or clarified, the requirement for hangars at airports that have received federal funds to be used for aviation purposes.
With the old language, there were some (idiotic) airport managers banning everything other than airplanes. No cars. No refrigerators. No chairs. Get that screwdriver outta here! The new language states that nothing can interfere with aviation purposes. As long as the hangar has an airplane, extraneous items are okay. As soon as non-aviation items evict an airplane, it is a violation. |
I had heard about that and thought it was a little crazy how over the top the airport managers were getting with this, glad they clarified.
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
