Whining sound coming from speaker, help?
I have to turn to you clever folks again.
I have a whining sound that seems to be coming from the speakers on my S2000. I check the radio ground and its tight and clean. Strange thing is that it whines little as I rev the motor, but once I let off the gas with it in gear, the whining sound gets loud but as soon as I get it out of gear or press in the clutch, it gets back to the slight sound I had before. This is driving me nuts . Where do you guys think is coming from. I am sure its a lose ground somewhere, but where to look and what does it have to do with the gear box? Stock radio btw.
Oh, I tried to turn off the radio and the slight whine still there. I do have an amp in there installed by the dealer. check that and the ground is solid and tight.
Make Bruins Great Again
Had that problem several decades ago when I installed an amp into my car. An RFI filter took care of it.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
You do not have permissi
There is a whatchamacallit inside the alternator for that very purpose.
Also another whatchamacallit in-line on the big wire going into the radio. Or somewhere about that area. Hope that helped. |
On a S2000?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
D idn't E arn I t
If it just popped up out of nowhere one of two things come to mind:
1)- an RCA cable is pinched somewhere, or partially out of the socket, causing a ground loop. 2)- amp has failed, blown internal ground. Check for a loose RCA or pinched or cut cable somewhere. Maybe someone ran a screw thru it. Happens. Disconnect RCA at radio, start car- whine still there (I suspect it will be since it's there radio off) get another rca- cheap one is fine, plug it in to radio and amp (don't bother routing it nicely- over the seats, whatever) and try again. If it's still there once you plug it in, likely you have a bad amp- internal ground has failed and is grounding thru RCA and radio. Could've popped for numerous reasons, but usually when you hear that kind of noise and the RCA's are OK then it's over. Check to make sure the speaker connections aren't touching metal somewhere in the doors as well, that will kill the amp.
AOC/Hogg 2028 |
I would look for a bad ground from the transmission/ motor to the body.
Slackerous Maximus
Turn off liberal talk radio?
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Old dog....new tricks..... |
. Last edited by wdfifteen; 01-19-2017 at 07:46 PM.. |
Long shot but how are your engine and trans rubber mounts? any chance one of your mounts is torn and your engine is moving more then it should tugging on some wires. check engine ground cable.
Is the amp wired by the dealer or factory plug in? If wired by the dealer check the wiring.
87 930, |
Band.
Don't rule out an ignition problem in addition to a stereo problem, even if the car is running well.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Goddarnit. This place is funny. Coffee through my nose
Band.
I'm really not sure on a modern car, but for example on our Porsches there was a RF supressor in the engine bay. I suppose something like that could go bad.
Hell Belcho
Ground strap. Hondas typically have it going from the valve cover to the body. Seen it cause this before. They are usually thin gauge and oxidize quickly.
Saved by the buoyancy of citrus. |
