abit off center
Phase converter single to three?
Moving my Bridgeport mill to my house, its setup for high volt 3 phase now but can be wired for 3 phase low volt too. Its a 1 1/2 HP motor
What are my options? I read about static phase converters that take single phase 220 which I have at home or they also have rotary phase converters that give you a true 3 phase? Anyone?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Platinum Member
VFD - Variable Frequency Drive
3 Phase from 2 with Variable speed. Variable speed for the mill will be a big help. Most also have 1 touch stop/run/direction faking 3 phase power at home Last edited by dad911; 02-26-2017 at 04:22 PM.. |
Bland
We went through this last week. Buy a 4KW vfd from eBay. They are $158 and there is a YouTube video that shows how to program it for a Bridgeport.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
abit off center
Dang you just saved me a lot of hassle and money! that's the way to go Thanks!
abit off center
So what size wire did you run to the vfd? I would have about a 60 foot run to get 220 to it.
Bland
figure out you amp draw and go from there...
5000W / 220v = 23A 10 gauge copper will be fine.
canna change law physics
Assuming the motor has a 1.85 SF, then the motor should pull about 2000 Watts or around 10 Amps. It should be fine with even #12 AWG, even with a 10% loss in the VFD.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
abit off center
I will run 220 single phase to the garage. The VFD will be mounted on the mill running the 1.5 hp 3 phase motor. That's the plan anyhow
Bland
Bland
Don't forget you need to oversize your power supply and vfd by 1/3rd if you are running a 3 phase vfd with single phase 220v. Hence the 5HP (4 kW) vfd.
I just realized that my above calculation is based on 5 kW so 12 gauge should be fine.
MAGA
Craig, I have run my 3 phase 1.5 HP Bridgeport for probably 10 years now using just a simple static phase converter. I have never had a problem..... that said, I do not do much heavy cutting. I cant remember what brand I bought, but it was well under $100 back then. I believe I have one rated for 1-3 hp. I mounted it to the wall behind my mill and ran power to it from my shops single phase 220 with 10ga Romex that I had laying around. A quick Ebay search turned this one up which is probably similar to mine.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
abit off center
Any issue with running a 4kw vfd on a 3/4 hp 3 phase motor? I have the mill and lathe I want to run,
Bland
You need a seperate vfd for each motor.
You can get a smaller vfd for the 3/4 hp motor for well under $50.
all VFDs have a current limit parameter.. you'll want to adjust that to the current rating of the motor
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
