vash's Avatar
what is a good strategy to bolt down a gun safe?
i can drill and epoxy in some studs..but the thought of moving a safe up and over some extended bolts does not seem like a fun way to spend a day.
i was thinking of emptying it, drilling down from the safe floor and use some concrete lag bolts..contractors call them red-heads or something.
i dont think tapcon makes a big/long enough conc screw or i would just do that.
poof! gone
Old 04-17-2017, 09:14 AM
craigster59's Avatar
I did mine just the way you said. Drill through the bottom of the safe and use Redheads.
Old 04-17-2017, 09:18 AM
My safe came with predrilled holes in the bottom, but I didn't use them initially...not worried sbout it being stolen. But the damn thing wanted to tilt forward when the door was open at a certain angle so it's bolted to the floor now .
I didn't use lag bolts....just regular bolts that I put nuts on from my crawl space...
Old 04-17-2017, 09:26 AM
It wasn't a gun safe, but I have bolted down a safe before. It came with a bolt and anchor and was predrilled on the bottom. What I did was mark the holes, move the safe, drill the holes, move it back, then bolt down. I would think you might have to do the same since I wouldn't think you could get the anchors through the hole in the bottom of the safe or they would be too small.
Old 04-17-2017, 09:43 AM
To answer the question, I would use bolts.
You might swing by a safe store and talk to them. See if they have any solutions.
Old 04-17-2017, 09:46 AM
GWN7's Avatar
Just fill it with enough guns & ammo that it is too heavy to move.
Bunch of old cars
Old 04-17-2017, 10:00 AM
id10t's Avatar
My cheap safe came with anchor holes set up already. Should I ever get around to putting it the back of our walkin closet Ill anchor it. Until then ....
Old 04-17-2017, 10:48 AM
vash's Avatar
oh..mine already has a few holes in the bottom. the floor is thick! i'd need hardward with some reach.
poof! gone
Old 04-17-2017, 10:56 AM
Tapcons are worthless for this. A prybar would pull them out.
Old 04-17-2017, 11:03 AM
Good point....I ran my two bolts through a 2x4 beneath my subfloor with big washers...it'd take some effort .
Old 04-17-2017, 11:07 AM
Ours came with the anchors and extra putty for the fire rating. They are or are similar to the Red Head Trubolt anchors.
Brent
Old 04-17-2017, 11:09 AM
Now in 993 land ...
aigel's Avatar
As mentioned, you use bolts and put anchors into the concrete. I blessed a rental home once with a couple. Now in a raised foundation home it is into 1" wood subfloor and 2x4 studs.
I'd like to get a bigger one ...
G
81 SC (sold)
Old 04-17-2017, 11:13 AM
Gon fix it with me hammer
svandamme's Avatar
This.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-17-2017, 11:17 AM
Use a wedge anchor. Get on McMaster Carr's web site and specify the length you need and order accordingly. If you want to do it in one step without moving the safe, buy some washers so you can enlarge the holes in the safe bottom big enough to insert the anchors through the holes.
Make sure you get the holes really cleaned out before inserting the anchors.
JR
Old 04-17-2017, 11:29 AM
Just returned from my sons home. He has 2 gun safes.
Your answer is to buy such a large safe, as his, that couldn't be moved by 2 or 3 strong men.
His are such that they will not be moved, unless professionally. Buy Big.
Old 04-17-2017, 12:24 PM
Any safe small enough to fit through my doors, can easily be moved by one man and an appliance dolly...jmo.
I have one..... But if a pro wants the contents....it's all over but the insurance settlement...YMMV.
Old 04-17-2017, 12:36 PM
JR
Yup, wedge is the way to go, make sure they aren't longer than your concrete is thick and drill much deeper than their length, put the washer and nut at the very top of the threads, hammer it down tight and then tighten the nut down. If you try to drill the exact depth and set them, you'll most likely have a bunch of thread sticking up.
Rutager West
Old 04-17-2017, 12:47 PM
If you just want it 'bolted' use tapcons. There are some pretty large tapcons available now.
If you want it held securely wedge anchors or fiber anchors are good.
Chemical anchors are probably strongest.
Old 04-18-2017, 04:17 AM
Slackerous Maximus
HardDrive's Avatar
It really about slowing people down. I really should bolt mine down, but I know for a fact that the slab is only 4 inches of concrete, with no rebar. Sledge hammer could break away the concrete around the safe in short order.
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 04-18-2017, 05:58 AM
vash's Avatar
i just kinda want to stop the meth addict knuckleheads..
my luck they try to tip the thing over and it falls on them and they sue my ass. i just want to keep it down so they cant scooch it up so they cant wedge a dollie underneath.
i can get into a safe and i am no safe cracker..i would use a portable bandsaw and cut off the hinge side/corner.
poof! gone
Old 04-18-2017, 07:10 AM
