pwd72s's Avatar
Originally Posted by aigel View Post
I would rebuild the engine and as suggested with some mild upgrades - Mainly an RV grind cam and a good quality timing set, rockers and pushrods. Rebuilding what you have will ensure 100% fit.
It is a fun project to rebuild yourself if you have a good machineshop to work with.
G
Ditto the RV cam. You want a flat torque curve for a 4X4, not high rpm horsepower.
Old 06-23-2017, 09:13 PM
Geoz1's Avatar
X3. Go here for a cam and lifters. COMP CamsŪ - Technical Support and Contact Page
Stick with a stock rebuild, performed by a reputable a machine shop, not a re-builder. New push rods, keep the OEM rockers, replace with OEM. Quality timing chain, Cloyes Double Roller. Std press and volume oil pump. Bearing clearance determines oil pressure. Use the oil viscosity and brand that the machine shop recommends.
Use the 1 qt. GM filter. Never use a Fram!!!
Old 06-23-2017, 09:58 PM
D idn't E arn I t
RANDY P's Avatar
Made a run to Tracy on the hottest day of the year so far. AC on during the flat freeway sections and kept it at 70-75. Saw 16.2 mpg which is higher than what I normally see. All on a motor with 317K. Does the phrase "glows brightest right before it............." mean anything.
I acutally average on the highway about 18MPG in my 89 Silverado, but it's lowered and has shorter wheels than stock.
When my motor croaked, it was due to flashes of overheating, and drinking water. Fill, bleed repeat over and over hoping it was just air- nope, blown HG. Mine had 272K on it at the time.
I was hoping that I could get away with rebuilt heads and new HG but when I pulled them the bores were visibly worn and worse, signs of rusting.
No mistaking those bores at that mileage as "in spec", that wasn't happening. all on the bank I pulled were sloppy. Would've taken .030 to clean them, easy.
rjp
In the movies only bad guys sleep in king size beds.
Old 06-24-2017, 05:55 AM
bugstrider's Avatar
Thanks Randy,
Since it's a K1500 4x4 with 285s(33"), my mileage has always fluctuated between crappy and $hitty, lol. My last spark plug swap I did notice some funky looking goobers on my #1 plug which very well could be coolant. Made me say WTH?!?!
"No! It's naht a toomah"
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 06-24-2017, 08:14 AM
DanielDudley's Avatar
Are you using oil ? Is your oil pressure OK ? Have you done a compression test ?
Old 06-24-2017, 08:18 AM
D idn't E arn I t
RANDY P's Avatar
sure looks like water and oil mixing up and solidifying, that's funky all right.
rjp
Old 06-24-2017, 08:19 AM
I'd do a GM crate. It will probably last the longest (maybe another 300k like the stock block). A rebuild from someplace else will probably not last remotely that long.
Old 06-24-2017, 09:34 AM
bugstrider's Avatar
Not really using any absurd amount. About a quart between oil changes. Temps and oil pressure right where they normally sit. I watch the gauges like a hawk. I haven't gotten around to a Comp check yet. But need to
1978 911SC Targa
Old 06-24-2017, 10:01 AM
bugstrider's Avatar
OEM Crate/Aftermarket Crate/Rebuilt GM 5.7 V8 for a K1500 4x4
rjp
Yeah, that's what I'm thinking but any coolant loss is barley/if any is even noticeable. I added a couple of ounces to the overflow tank two months ago. Radiator is sitting full.
Who knows, I'm probably operating on a wing and a prayer and when it decides to let go...... it will be spectacular!
1978 911SC Targa
Old 06-24-2017, 10:04 AM
bugstrider's Avatar
That's what I'm vectoring towards. Hopefully I might have a line on one from a dealer.
1978 911SC Targa
Old 06-24-2017, 10:07 AM
