Shaun @ Tru6's Avatar
Originally Posted by berettafan View Post
Shaun I really think the purchase of a legit steam power washer is worthwhile for you. I'd imagine you could pick up some side work that would make short work of the cost of such a thing. maybe even just using it to help friends in the trade/business and swapping work.
IMO either buy a $200 sams club cheapie and replace it from time to time or go whole hog and buy the real deal. consider speeders pic of his engine bay. using cold pressure (or warm pressure) you would destroy lots of rubber and have water intrusion issue to get even half that clean.
It's all about budget. I'm not sure what you mean about side work, I'm booked into February working 65+ hours a week now and can't find an assistant to save my life.
To your point, any device that saves time is money well spent. I can envision it so easily with the vapor blaster. A hot water pressure washer takes a long time to amortize I think.
Tru6 Restoration & Design
Old 10-17-2017, 11:34 AM
Brew Master
cabmandone's Avatar
Dang it! I wish you would have posted pics of what you were fighting. I used some stuff called Black Jack that I bought from Lowes to remove some goo that was in my wheel wells. Just sprayed it on, let it sit for a while, hit with a wire brush and then pressure washed it off. And yeah a hot water washer would have made a difference on that. I don't think a turbo nozzle would have done much good as that stuff needs to be softened before it will come off. That's where the high heat comes in really handy. I can lower my pressure and crank up the heat and have it go to steam if I want to. I don't use it like that often as it's hard on the heating coil to get them that hot.
As a side note, I'd look into ZEP products. They have a citrus based cleaner that people in asphalt use to get the asphalt off of their skid loader and out of the bucket. I'll talk to my cousin if you want and get the name of the stuff. I have used it before and it works well.
Old 10-17-2017, 01:05 PM
this stuff? https://www.lowes.com/pd/BLACK-JACK-12-fl-oz-Masonry-Cleaner-for-Asphalt-Brick-Concrete-Mortar-Stucco/3333888
Old 10-17-2017, 01:09 PM
Brew Master
cabmandone's Avatar
How many hours did you spend using the cold water blaster? Time is money! What you need to do is move closer to me! That way you can put my son to work and use my pressure washer.. and all for the small small fee of making my car look better!
Old 10-17-2017, 01:10 PM
Brew Master
cabmandone's Avatar
That's the stuff! Worked great when I was cleaning up my wheel wells. Someone had put some stuff in there that covered the original white paint. I was trying to be careful not to hurt the paint yet get the black stuff off.
Old 10-17-2017, 01:12 PM
The gas worked pretty well but I bet this would have been better. I couldn't find it at HD (2 miles away) and Lowes is 30+ minutes. Will see if corner hardware store has it.
Old 10-17-2017, 01:14 PM
as long as I get some beer in the deal.
3 hours total on the car. I bet with a hot water washer I could have done it in 1 hour. So that's $200 burned. And that's the problem, I don't do enough cars to justify the $2K+ for the hot washer.
Old 10-17-2017, 01:18 PM
Brew Master
cabmandone's Avatar
I'd keep my eyes open on CL. I bought my Easy Kleen for 2K at an auction and it was new. I'd guess if you watch CL you'll find a decent one for around 1K. But then again, you live in the high rent district of the country . If you want I'll have my B.I.L on Nantucket keep his eye open for a deal. He's a CL junkie. I'd still want something capable of producing 3000 psi even with heat.
Old 10-17-2017, 01:25 PM
Brew Master
cabmandone's Avatar
Yeah, ya can't drive 30 minutes even if the stuff did work better and I'm not 100% sure it would but with my experience using it, it worked well.
Old 10-17-2017, 01:27 PM
I will add it to my CL regimen though CL is getting expensive these days, accidentally bought another car 2 weeks ago.
Brew Master
cabmandone's Avatar
Just thought of something else you might try if you still have some of that tar remaining. Citri Strip is a paint remover that is citrus based (obviously). It's thick and can be applied with a brush. If you put it on and let it soak for a bit, it might soften the tar the same way that Zep stuff does.
Old 10-17-2017, 01:36 PM
That is a good idea, I used to use that for removing window frame seals before I found brake cleaner works so much better.
Old 10-17-2017, 01:40 PM
madmmac's Avatar
It's not so much the psi that gets things done, it's the gpm.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 10-17-2017, 07:57 PM
Brew Master
cabmandone's Avatar
Adding to madmmac's point, my Easy Kleen is a 4 gpm unit IIRC. But PSI doesn't hurt when I can crank it up to 4000 plus add high heat.
Pressure washers are kind of like leaf blowers. Most leaf blowers advertise their air speed in MPH but CFM is where the work gets done.
Old 10-18-2017, 06:18 AM
The good news is I just dropped off the tub to the body shop I work with/rent and the owner (ex-Paul Russell) liked the cleaning job. Definitely more cleaning/sanding to be done but I was afraid he was going to send it to a blasting service.
I think the net here is as Nick says, keep an eye on CL for a good deal on a hot tank washer.
Old 10-18-2017, 08:37 AM
Brew Master
cabmandone's Avatar
Once every blue moon I come up with a good idea.. Well, maybe not that often. What you need to do is exactly what my brother does to me. He calls, asks my opinion on something and then generally does the exact opposite! I'm not sure how well it works for him, but he keeps doing it so it must work ok.
Old 10-18-2017, 08:40 AM
The 9 Store
Those do look nice. I typically bead blast and then tumble Al and Mg. I can control the surface sheen with media and various techniques and I like that the media micro-peens the surface to seal it. The Mg 915 below is 2 years done and still glows. My sense is the vapor blaster will shorten the time I need to get to the final finish and sometimes give me a final finish.
The hubs took me less than 5 minutes. Trailing arms are 5 minutes each. Trans is 10-15 because of all the books and crannies.
The crossmember was the typical tar covered old looking part. Less than 10 minutes to make it look like new. But our unit is one of the larger ones.
All used parts sold as is.
Old 10-19-2017, 12:05 PM
What model do you have? Please post or PM me a link.
Old 10-19-2017, 12:17 PM
The 9 Store
It was a lightly used model. Around $25K if new. Probably a bit bigger than we need but... uses a LOT of air.
Old 10-31-2017, 05:03 AM
The 9 Store
Pics
Old 10-31-2017, 05:07 AM
