resident samsquamch
The anchor points are about 18' up. And I was trying to obtain a very natural (that word again) swinging motion.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
resident samsquamch
So now, we're thinking about cutting and using one of those smaller trees in the left corner to use as a horizontal beam.
hey flipper i think we are hiring!! wanna job?
poof! gone |
resident samsquamch
So I'd have to make the swing ropes extra long so that when I pulled them together, I'd end up with the correct final length.
resident samsquamch
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
You need something rigid between the trees. It will take a lot of Viagra to make that rope work.
resident samsquamch
I'm an IT Business Analyst and Product Owner! I have used this cartoon in more PowerPoint presos than I care to admit! LOL!
That is EXACTLY the image I thought of when I opened this thread!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
A piece of pipe spanning the trees would work better. I'll let Cliff determine the size of the pipe needed. Then either drill it for some eyelets or weld some on at the desired spacing
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
A pipe would solve the sagging/sideways tension, while you could still run the rope through the pipe to attach to the tree trunks in a loop. Screw on a round floor base flange to each side to lessen the damage to the tree, and tie a rope through the flange holes tightly.
resident samsquamch
A pipe is an excellent idea! I had not considered that!
You could also run 5/16" wire rope between the trees using Crosby clamps to secure it to itself once looped around the branches. Fit a rubber sleeve over the wire rope where it contacts the branches to prevent it from digging into the wood. Tension as necessary, and use (2) additional Crosbys on either side of each swing rope(total of (4) to keep the swing centered on the cable, use oversized washers between the swing hangers and Crosby to allow smooth movement, and use a carabineer to attach swing rope to wire rope.
Eric 83 911SC/83 944 bunch of Honda 750s 69 Chevrolet C-20 Longhorn (family heirloom) |
resident samsquamch
Platinum Member
OMG, I'm an engineer, and you guys are way over thinking this. Tie a rope to each tree, a tire in the middle, and let the kids have fun. If you really want a classic swing, connect a 4x4 to both trees and attach swing to it.
How much of a hill is there? It's best to swing out over the hill. Or tie a cable to a tree on the hill about 10' high, other end to the house or a lower tree, and attach a pulley to a T handle.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Again, those trees are going to move a great deal when there is wind so any beam or pipe attachment will have to account for that movement.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Personally I would do a zip line also.
Wrapping anything around the trunk or a branch may, in time, kill the tree or the branch.... aka "girdling" (the tree's vascular system runs just inside the layer of bark). I might consider this, instead. Boring through the trunk of a tree will not kill the tree. It would be easy to try and you'd know quickly whether the tree could withstand the forces of unfettered swinging.
'70 911S 1002938 '70 Ducati Mark 3D 350 |
