resident samsquamch
sand_man's Avatar
The anchor points are about 18' up. And I was trying to obtain a very natural (that word again) swinging motion.
-jeff
Old 03-27-2018, 10:11 AM
resident samsquamch
sand_man's Avatar
So now, we're thinking about cutting and using one of those smaller trees in the left corner to use as a horizontal beam.
-jeff
Old 03-27-2018, 10:12 AM
vash's Avatar
You could put a chain/rope across 4' above the seat to pull them together to hold onto easier.
Yes, that pic is what I was getting at.
this changes everything. this would work.
hey flipper i think we are hiring!! wanna job?
poof! gone
Old 03-27-2018, 10:17 AM
I think you could go with your original idea with a big thick rope across the span. A few loops around each trunk (above the small branch nook) and cinched good & tight in some fashion...Cliff can engineer the knot
resident samsquamch
sand_man's Avatar
So I'd have to make the swing ropes extra long so that when I pulled them together, I'd end up with the correct final length.
-jeff
Old 03-27-2018, 10:27 AM
resident samsquamch
sand_man's Avatar
This just looks bad:
https://www.etsy.com/listing/467203899/swing-hanging-kithanging-a-swings?gpla=1&gao=1&utm_campaign=shopping_us_WoodSwings_sfc_osa&utm_medium=cpc&utm_source=google&utm_custom1=0&utm_content=5432904&gclid=Cj0KCQjw1-fVBRC3ARIsAIifYOO002ij7a6tO3upkK7hyyA3SLBkrEjE9QnF S0Fec3SC6rpTD7DMVR4aAogiEALw_wcB
-jeff
Old 03-27-2018, 10:33 AM
canna change law physics
red-beard's Avatar
James
Red-beard for President, 2020
Old 03-27-2018, 10:37 AM
wdfifteen's Avatar
You need something rigid between the trees. It will take a lot of Viagra to make that rope work.
Old 03-27-2018, 10:41 AM
resident samsquamch
sand_man's Avatar
Originally Posted by red-beard View Post
I'm an IT Business Analyst and Product Owner! I have used this cartoon in more PowerPoint presos than I care to admit! LOL!
-jeff
Old 03-27-2018, 11:00 AM
Not an engineer here, but a mechanical mind none the less. Wouldn'there be two different pivot points (one a few feet above the riders head, and another at the knots on the tree 18' off the ground) on the swing above, which might make the swinging experience a little awkward ? It would just seem to be a two-stage swing that might give a not so smooth effect ?
Old 03-27-2018, 11:02 AM
MBAtarga's Avatar
That is EXACTLY the image I thought of when I opened this thread!
Mark
'83 SC Targa - since 5/5/2001
Old 03-27-2018, 11:07 AM
pete3799's Avatar
A piece of pipe spanning the trees would work better. I'll let Cliff determine the size of the pipe needed. Then either drill it for some eyelets or weld some on at the desired spacing
Pete
79 911SC RoW
Old 03-27-2018, 11:18 AM
A pipe would solve the sagging/sideways tension, while you could still run the rope through the pipe to attach to the tree trunks in a loop. Screw on a round floor base flange to each side to lessen the damage to the tree, and tie a rope through the flange holes tightly.
Old 03-27-2018, 11:37 AM
resident samsquamch
sand_man's Avatar
A pipe is an excellent idea! I had not considered that!
-jeff
Old 03-27-2018, 11:38 AM
Eric 951's Avatar
You could also run 5/16" wire rope between the trees using Crosby clamps to secure it to itself once looped around the branches. Fit a rubber sleeve over the wire rope where it contacts the branches to prevent it from digging into the wood. Tension as necessary, and use (2) additional Crosbys on either side of each swing rope(total of (4) to keep the swing centered on the cable, use oversized washers between the swing hangers and Crosby to allow smooth movement, and use a carabineer to attach swing rope to wire rope.
Eric
83 911SC/83 944
bunch of Honda 750s
Old 03-27-2018, 11:48 AM
resident samsquamch
sand_man's Avatar
Yes, I think "crosby clamp" is what I was really thinking when I said "U-bolt". Thank you for the correction.
-jeff
Old 03-27-2018, 12:21 PM
Platinum Member
dad911's Avatar
OMG, I'm an engineer, and you guys are way over thinking this. Tie a rope to each tree, a tire in the middle, and let the kids have fun. If you really want a classic swing, connect a 4x4 to both trees and attach swing to it.
How much of a hill is there? It's best to swing out over the hill.
Or tie a cable to a tree on the hill about 10' high, other end to the house or a lower tree, and attach a pulley to a T handle.
Old 03-27-2018, 12:44 PM
Again, those trees are going to move a great deal when there is wind so any beam or pipe attachment will have to account for that movement.
Brent
Old 03-27-2018, 12:46 PM
Personally I would do a zip line also.
Brent
Old 03-27-2018, 12:47 PM
derek murray's Avatar
Wrapping anything around the trunk or a branch may, in time, kill the tree or the branch.... aka "girdling" (the tree's vascular system runs just inside the layer of bark). I might consider this, instead. Boring through the trunk of a tree will not kill the tree. It would be easy to try and you'd know quickly whether the tree could withstand the forces of unfettered swinging.
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 03-27-2018, 01:01 PM
