teach me about hammer drills/rotary drills
Pretty soon I will be installing my 2 post lift . I will have to drill 12 holes 3/4 " in diameter and about 6 " deep . This concrete is high strength fiberglass reinforced and was poured aprox. 6 months ago . Yesterday I drilled 4 holes with a standard 1/2 " drill with a 1/2 " standard masonary bit and it was tough going !!! So my understanding is there are hammer drills and rotary drills .
I'm not going to buy one I will rent one , but which is the better tool for what I need to do ? These will be vertically drilled holes so line the bit up , stand over the drill and go to town . Advice from those that have used these is appreciated .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Go big!
I have a 1/2 hammer drill that is great for small occasional jobs. I tried to punch a 1 inch hole through the stem wall of my house. After 30 minutes I was just part way done. I went and rented a big Bosch hammer drill. It punched through in a couple of minutes. It was an amazing difference. That was 20 years ago and I know things have changed. Renting is for sure the smart move.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
The Unsettler
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I bought this to install my maxjax in my garage. This is the first link I found but I think it was under 200$ at one of the amazon vendors (refurb).
https://www.amazon.com/Bosch-RH328VC-RT-SDS-Plus-Rotary-Hammer/dp/B004KCQSO6/ref=sr_1_12?ie=UTF8&qid=1523453736&sr=8-12&keywords=bosch+hammer+drill It laughed at drilling the 6" by 1" holes in my garage. It seemed to taunt me with "is that the best you got?". Anyways no problem you could prob get away with a smaller model. On the rent vs buy: I was in for about 210$ for the drill and bit, vs 50$ + tax + bit for rental. I was going slow and careful and it was great to not have to be in a hurry to return the tool. I figure if I use it one more time if if I lend it out a couple times it was worth buying. My buddy has already used it for a bigish job
84 930 07 Exige S |
Platinum Member
SDS bits/system. I've used the harbor freight one, it will get it done. Less than $100 with bits. Also works as a small jackhammer for light demo.
https://www.harborfreight.com/power-tools/hammer-drills/1-in-sds-variable-speed-pro-rotary-hammer-kit-63433.html https://www.harborfreight.com/12-in-SDS-Masonry-Bit-Set-5-Pc-62480.html
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk |
Also for your real question. Its pretty straight forwards you just need the rotary hammer and the bit. No pilot hole. Dont put any downward pressure on the drill, it needs to bounce.
The most important thing is to be OCD about cleaning the holes, particularly if you are using epoxy set anchors. I managed to find an appropriate sized stiff wire brush. The cleaning and vacuuming is the worst part. It is best to have a template to drill thorough. I just left the posts standing to do this. I heard some stories about excessive walking if you try to do it freeform. Each hole takes less than 1 min with the rotary hammer. I used a Bosch Bulldog bit
84 930 07 Exige S |
sds are the smaller bits and drills which are prob fine
sds plus is the medium sized setup which is what I used and sds max are the big dawgs
84 930 07 Exige S |
Platinum Member
Good points Aschen.
As I recall I did it with lift standing also. I vacuumed them out, then cleaned.
When drilling anchor bolts we use hammer drills with SDS bits. As was mentioned, when drilling, be sure to stop occasionally and vacuum out the holes( a shop vac with a narrow tube taped to end works well). A quick cheat, determine the depth required, measure bit, and install electrical tape at the correct depth on the bit so you know when you get the correct depth.
Eric 83 911SC/83 944 bunch of Honda 750s 69 Chevrolet C-20 Longhorn (family heirloom) |
I rented a rotary hammer drill from the lcl home depot. I bought my own bit vs renting that too, a SDS plus 7/8" bit. I initially used a 5/8" bit to start a couple holes thru the lift mount holes and then enlarging the holes. I was not happy doing that so I marked the floor and drilled with the correct size all the remaining holes. Marked the bit with tape for depth. Worked perfectly. Just drill with easy pressure and back out often to remove the material. It's a quick job.
Getting the holes perfectly vertical is the hardest part. I cleaned the holes very carefully and repeatedly as I was using epoxy set anchors as well. Vacuuming with a small tube, brushing, very important to get those things dust free. Buy an extra tube of epoxy to have on hand. You'll use more than you think. And clean those holes one more time just for chits and grins.
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
I bought an sds hammer and its useful but I dont use it much. Rent one from HD. I used their medium sized sds for some some foundation penetrations and it was pretty amazing how fast it went.
Great advice guys thank you
Model Citizen
At least one. Might as well get a couple; it's spendy enough that you'll definitely take back the tubes you don't use. If you've never used this stuff, make sure to watch videos on how to use it. In my experience, it set lots faster than I thought it would, but because I kind of knew what to expect, and I had sort of done a dry run, things worked out.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Retired Member
Rent a Bosch or Hilti hammer drill, like a hot knife through butter
80 911 SC sold 17 Tahoe 07 Z06 Corvette ![]() |
I found that drilling the holes first with an 1/8” bit helps to get the big holes lined up for accurate placement, otherwise they bounce around and the holes are off.
Rutager West 1977 911S Targa Chocolate Brown |
Misunderstood User
You should drill through the concrete. If you ever need to remove the lift you can simply hammer the anchors thru the concrete. Otherwise you need to grind them flat. The template is a good idea as well.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
This is the install kit I purchased , it states they are wedge bolts . They are 3/4 " diameter so I drill a 3/4 hole correct ? No mention of epoxy but epoxy could be added right ? Or is there no value adding the epoxy ? In regards to the bit wandering I was planning on using the holes in the foot of each post as my drill guide that will work right ?
I figure I will drill the holes , insert shims as needed and install the bolts . If you guys think some epoxy would be good " insurance " then I will do so . I want to do this right the first time ![]() https://www.carliftparts.com/product/bendpak-lift-installation-install-kit-16-wedge-anchor-bolts-30-pack-shim-kit/
No need for epoxy, generally you use the same size drill as the nominal size, I'm not a fan of the plastic shims. I usually use Hilti products, not generic/unbranded stuff.
You can use the base plate to drill through if there's enough room between the posts and the hole locations for the drill to fit. If the holes in the base plate are oversized, though, I'd probably make my own drill guide. |
Don't epoxy the wedge bolts. If it ever fails your insurance company will blame you for it.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Thread Tools | |
Rate This Thread | |
