Checked out
McLovin's Avatar
Did I just break the record for world's oldest water heater?
I just replaced my water heater. It caused me to research them, and I saw they typically last 8-12 years or something like that.
The one I just took out was made in . . . 1981! It's in a house I own that was built around that time.
So yeah, it went 36 years.
That, of course, without any of that mamby pamby stuff like replacing the anode rod every few years, occasionally draining it, etc. Nope, it just sat there heating water since the opening days of the Reagan Administration.
Old 05-22-2018, 03:30 PM
Good luck with the new one, most of them are junk from what I've read. It's the electronics, they suck.
Ours was old when we replaced it, but I'm guessing you beat us by at least a decade.
Old 05-22-2018, 03:43 PM
Unregistered
sammyg2's Avatar
Pretty sure it's called a hot water heater.
I heard that somewhere
Old 05-22-2018, 03:49 PM
pwd72s's Avatar
Submit to Guinness...
Old 05-22-2018, 03:53 PM
I'm guessing that you either have soft water in that area...or the house has a water softener installed.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 05-22-2018, 04:01 PM
Functionista
manbridge 74's Avatar
Recently replaced mine from 1991. Pretty hard water around here. No anode replacement.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-22-2018, 04:50 PM
CurtEgerer's Avatar
Was it a Lochinvar? I've seen several of those go 40-50 years. Not sure about current quality or if they're even around anymore.
Old 05-22-2018, 08:26 PM
Nope. Water heater.
Old 05-22-2018, 09:32 PM
That's got to be a record of some kind. The most I got out of one was a hundred gallon Rheem in a six unit apartment building. It lasted for 17 years. I think I jinxed it when I started worrying it was getting old & realized how long it had been in there. Naturally it started leaking not too long after that.
Marv Evans
'69 911E
Old 05-22-2018, 09:36 PM
Run smooth, run fast
Heel n Toe's Avatar
Originally Posted by tcar View Post
Nope. Water heater.
Yup... sez so right on the sticker.
- John
Old 05-23-2018, 12:48 AM
Almost Banned Once
sc_rufctr's Avatar
I just replaced mine. 9 years old and it failed with no warning!
Old 05-23-2018, 02:07 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Hot water heaters used to be designed to make hot water. Now they're designed to sell more hot water heaters.
Black Cars Matter
Old 05-23-2018, 02:51 AM
T77911S's Avatar
mine went close to that. it was original for the house and I am sure it was built in the 70's.
it said something about "fiberglass" on the outside. fiberglass tank instead of I assume copper.
the one I replaced it with has a lifetime guarantee. only one I have ever seen.
now a days the tanks literally last as long as the warranty.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-23-2018, 04:07 AM
Wetwork
Had a hot water guy show me one time the higher on the tank the anode is the longer they last..
So if at all possible you are money ahead to find one with the highest one up the side of the tank. Even with routine flushing the instant the anode touches some sediment it's toast. If you look you can see the extra ports where the factory can weld in the anode higher or lower depending on how long the warranty is for. It's a con job for sure.-WW
Old 05-23-2018, 05:49 AM
My parents had once last about as long. They had a deep freeze that lasted through two moves to and from Hawaii, as well as 15 moves to different houses by Air Force contract movers. It still went over 40 years. It was the ONLY appliance that survived a power line to the house having a tree fall on it and cause the neutral to become a hot and all the devices plugged in got 220 volts. It fried everything in the house, except that old freezer.
Yea, water heaters are like many appliances now, disposable. Our washing machine is an old top loader and over 25 as is the matching dryer. New fridges are the worst for short life. Our is 20 years old.
Old 05-23-2018, 05:55 AM
Geoz1's Avatar
The 2 AO Smiths were installed in my house in 1977. I replaced one 4 years ago, the other 3 years ago. The house was on a well until 1984 or 1985. There is no visible cues that a water softener was ever installed. I try and drain the tanks once a year. Sometimes I forget.
If I would have changed both at the same time, I would have saved a few hundred dollars. The price went up, as the water heater became "smarter".
Old 05-23-2018, 10:26 AM
