Checked out
Did I just break the record for world's oldest water heater?
I just replaced my water heater. It caused me to research them, and I saw they typically last 8-12 years or something like that.
The one I just took out was made in . . . 1981! It's in a house I own that was built around that time. So yeah, it went 36 years. That, of course, without any of that mamby pamby stuff like replacing the anode rod every few years, occasionally draining it, etc. Nope, it just sat there heating water since the opening days of the Reagan Administration. |
Good luck with the new one, most of them are junk from what I've read. It's the electronics, they suck.
Ours was old when we replaced it, but I'm guessing you beat us by at least a decade.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Unregistered
Pretty sure it's called a hot water heater.
I heard that somewhere ![]() |
Submit to Guinness...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I'm guessing that you either have soft water in that area...or the house has a water softener installed.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Functionista
Recently replaced mine from 1991. Pretty hard water around here. No anode replacement.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Was it a Lochinvar? I've seen several of those go 40-50 years. Not sure about current quality or if they're even around anymore.
That's got to be a record of some kind. The most I got out of one was a hundred gallon Rheem in a six unit apartment building. It lasted for 17 years. I think I jinxed it when I started worrying it was getting old & realized how long it had been in there. Naturally it started leaking not too long after that.
Marv Evans '69 911E |
Run smooth, run fast
- John "We had a band powerful enough to turn goat piss into gasoline." |
Almost Banned Once
I just replaced mine. 9 years old and it failed with no warning!
Dog-faced pony soldier
Hot water heaters used to be designed to make hot water. Now they're designed to sell more hot water heaters.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
mine went close to that. it was original for the house and I am sure it was built in the 70's.
it said something about "fiberglass" on the outside. fiberglass tank instead of I assume copper. the one I replaced it with has a lifetime guarantee. only one I have ever seen. now a days the tanks literally last as long as the warranty.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Wetwork
Had a hot water guy show me one time the higher on the tank the anode is the longer they last..
So if at all possible you are money ahead to find one with the highest one up the side of the tank. Even with routine flushing the instant the anode touches some sediment it's toast. If you look you can see the extra ports where the factory can weld in the anode higher or lower depending on how long the warranty is for. It's a con job for sure.-WW |
My parents had once last about as long. They had a deep freeze that lasted through two moves to and from Hawaii, as well as 15 moves to different houses by Air Force contract movers. It still went over 40 years. It was the ONLY appliance that survived a power line to the house having a tree fall on it and cause the neutral to become a hot and all the devices plugged in got 220 volts. It fried everything in the house, except that old freezer.
Yea, water heaters are like many appliances now, disposable. Our washing machine is an old top loader and over 25 as is the matching dryer. New fridges are the worst for short life. Our is 20 years old.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
The 2 AO Smiths were installed in my house in 1977. I replaced one 4 years ago, the other 3 years ago. The house was on a well until 1984 or 1985. There is no visible cues that a water softener was ever installed. I try and drain the tanks once a year. Sometimes I forget.
If I would have changed both at the same time, I would have saved a few hundred dollars. The price went up, as the water heater became "smarter". ![]() |
Thread Tools | |
Rate This Thread | |
