Don't think I would shoot a tennis ball. But I'm a pooosy.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
. He can do a 3" group at 450 yds with his hunting rifle, but we don't have "no contests" with air rifles either. I don't shoot that much....took a few decades off, but then I discovered PPOT....and Higgins....damn him, or thank him....I can't decide . Shooting is fun....but I'm not big on formal ranges and punching holes in paper either.To the OP....if you are that new to spoons, methinks you're doing fine just starting out....some of these guys are trained pros who've been shooting for decades....at a VERY high level....if I may say so .
You appear to be bladed-off to the target quite a bit as well, as opposed to being more squared up to it. So, maybe try squaring up to (facing) the target, and work on getting a proper check weld on the actual stock body. Pull the bottom of the stock firmly into your shoulder pocket or upper side of your pec (whatever your preference), keeping that “chicken wing” down. Basically you want to get the highest cheek-weld on the stock that is comfortably possible while still being effective at mitigating the effects of recoil (though not really an issue with .223/5.56). Then let your cheek fall naturally on the stock to get your sight picture/sight alignment. Just try to avoid craning your neck forward, or drooping it down too much. Do that in conjunction with getting the fit/ergos right. Assuming that stock is adjustable, find what setting works best for your desired length-of-pull and proper eye relief for your scope. This might take some experimentation and moving the scope mount back/forward to get everything just right. Some scopes have a more forgiving "eye box" than others, so the sweet spot (no scope-shadow) will vary from scope-to-scope. Make sure the scope diopter is set to your eye as well. Just hold it up to the sky and adjust the diopter until the reticle is tack-sharp. Do this in brief “sessions” as your eye will compensate quickly. After getting all the ergos dialed in, practice getting that consistent cheek-weld, using reference points on the rifle/stock if needed. You might also experiment with different grips to find out what size/angle/trigger length works best. Also, if you are doing your part, and accuracy is still sub-par after trying different ammo, make sure the mechanicals on the rifle (and optic) are all in order. If you have a loose barrel nut, scope rings, scope base/mount, etc., you will be chasing your zero forever and accuracy will suffer. For the scope rings/mount, it can be helpful to use witness marks on the fasteners once everything is properly torqued down. This lets you visually verify that nothing has come loose and also lets you return the mount to the same approximate torque when removing/reinstalling. If it's a QD mount, make sure that the clamping force/tension is adjusted to be tight/solid. You might want to do a couple box/tracking tests with the scope as well, to make sure it's functioning correctly (repeatable), and not a lemon.
I’m 6’-4” and 250. The spoon feels small for me. If I shorten the stock, I can’t get my shoulder / eye to the scope comfortable, but I’ll try the good advice from everyone.
Lots to try this weekend! Quote:
Gon fix it with me hammer
if you move your head around and you have paralax settings set incorrectly the resulting error is huge. Or don't have any on the scope you use, same thing. Move out to 300 yds and the problem goes away. At some point I thought my scope was defective. Hadn't shot 100 in a long time, came back from Norway, wanted to load ammo and test some things at 100. couldn't group to save my own life. Went to UK to shoot (where we never went shorter then 600 yds) and used a friends scope, no more problem. So i decide i'll buy a new scope scope arrives Same ******* problem. at 100 yds when i tried to zero it. Got a friend to shoot both scopes He was shooting sub MOA.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 06-07-2018 at 08:55 PM.. |
A930Rocket, your spoon feels small to you because it is. A carbine with a 16" barrel and adjustable stock.
For long range accuracy, ya need a 28" barrel and a sight radius around 30". I built this 223 match rifle a couple years ago and only shot it enough to break in the barrel. Me thinks I need to get out and do some long range shooting. ![]()
A tennis ball at 30-40 yards? That's a handgun target. Peacemaker with original spec black powder loads, shooting bullets cast in my garage. My "standard" air rifle target in the back yard is a beer bottle cap, suspended on a wire hanging from the laurel hedge at about 25 yards. Painted orange so I can see it. Offhand only, peep sights only. If I can't hit it nine out of ten times, I grab another beer...
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
[QUOTE=Jeff Higgins;10065950]I love this place...
A tennis ball at 30-40 yards? That's a handgun target. Peacemaker with original spec black powder loads, shooting bullets cast in my garage. My "standard" air rifle target in the back yard is a beer bottle cap, suspended on a wire hanging from the laurel hedge at about 25 yards. Painted orange so I can see it. Offhand only, peep sights only. If I can't hit it nine out of ten times, I grab another beer... [/QUOTEHa! My Webley Tempest target is an aspirin super glued to the nuts of my neighbor's black cat. Standing in my patio, if I can't hit it the first time he comes scampering over my cinder black wall 60 yards away, I make an appt. w/my psychiatrist. ~~~~~~~~~~~ ![]() ~~~~~~~~~~~
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View Last edited by Don Ro; 06-08-2018 at 03:06 AM.. |
. I just mentioned a tennis ball...'cause there was a dawgy ball in my yard....Most of us casual shooters are just that...I have no doubt that I suck, compared to the best....just like every other activity I've ever done...sports, etc. But it's all about having fun..... Thank you Jeff (and others)....this board rekindled that many years ago
My mother's second husband was a farmer in N.D. His older brother brought home his Army M-1 carbine.
The summer after I graduated HS, I worked on the farm digging, plowing, etc. I'd grab the carbine and a pocket full of ammo after breakfast and stop work in the field when I saw a varmint or just to take a break to shoot at a white rock. In boot camp that autumn ('63) we shot the same carbine...I was relieved. I shot one count less than a perfect score. Got an expert medal which I seem to have lost somehow. I've always been a good shot...until that Webley Tempest (above) came into my life a couple of years ago. I think that Jeff H. turned me onto it. I hunted all of my youth in N.D. .222 and a 30-06 mostly. .22 for gophers. . Dead Eye Don.
I had no idea what parallax was until I watched the video below. I’ll check it tomorrow if the rain holds out.
Does my scope have parallax adjustment? From the Amazon website: 100-yard Parallax Setting-Eliminates parallax for precise shooting. http://www.amazon.com/exec/obidos/redirect?link_code=ur2&camp=1789&tag=wwwpelicanpar-20&creative=9325&path=https://www.amazon.com/gp/product/B006YVT0R8/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1 Quote:
Finding a round that works can make a huge difference because of twist rate and the barrel harmonics.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Just a fun old shooting tale. Sun Valley Porsche Parade, 1971. Noticed there was a range at Sun Valley, so I tossed my Browning Challenger and a few hundred rounds of CCI .22 LR in my luggage. Oregon Region cocktail party the night before, talking shooting with another guy, we planning to go to the range the next day. A wife of another guy said her hubby Vic loved to shoot. So, now we were three.
Next day, walking into the range..Rangemaster; "Vic! Remember me? I left the Corps the year you got the best new shooter award." Whoops..Vic a marine. Never touched a firearm until basic. When it was noticed he had an apptitude for the handgun, he was taken aside..his entire time served was representing the Corps in shooting. That day, I learned a lot... Vic said my Browning was one of the best out of the box pistols he'd shot. I asked if he did his mods. Nope, he'd just hand it to a gunny and describe what he liked or didn't like. To rifles...I loved going to the range with my deer rifle. A plain jane model 722 Remington...1950's vintage. I did have it glass bedded, topped with a 4X with duplex hairs. I'd put it against an AR15 @ 100 yards...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
But don't let that fool you, there is no such thing as a perfect setting at 100 yds. A scope with parallax adjustment would have either a 3rd turret on the left, an Adjustable Objective up front . Having adjustment doesn't change that you need to figure out how to detect that you need an adjustment. No need to go to the range to figure out how the error works. if you have a garage, or living room that is 10 meters long, or something like that. put up a playing card, fix your rifle in a vice or on a sand bag, so it can't move and bob your head around, you'll see what happens the reticle will move around over the playing card.. That's parallax at work for you. Now look around at the dark ring around your reticle see how it comes and goes and moves around. Thats what you need to be weary off when you shoot. Find the right cheeckweld, where the shadow ring is just gone. And learn to check your hold before each shot, check if you see the ring, if you do, don't shoot and check your cheekweld.. Anyway, play around with it at home, and you'll waste less time and ammo at the range..
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 06-08-2018 at 01:46 PM.. |
So, if you are shooting targets at 100 yards it's even more of a non-issue. Still, it's good to practice getting a consistent/repeatable check-weld/sight alignment. Iron sights are good for that.
True story (not that the above wasn't... ): We used to hold an informal "fly shoot" at my club range. For whatever reason, flies are attracted to WD 40... So, of course, the obvious thing to do is to turn the target paper around backwards, so it's blank, and hose it down with WD 40 before hanging it at 100 yards. Then just sit at the bench and wait for the flies...Hits had to be confirmed by a spotter. Flies tend to disappear when hit with centerfire .22's and 6mm's. They often won't even leave a splat. After awhile, of course, it started getting down to where you hit the fly. At that point, we had a number ink stamps of a life size fly made up, complete with scoring values. Head shots were five points, body three, wings one. We spent countless hours stamping flies on the backs of target paper. Things were getting pretty serious. The semi-official Kenmore Ranges Fly Shoot went on semi-regularly for years. To be competitive, you had to be able to consistently hit the head. Top benchrest competitors from the area found this to be their most fun, and most challenging match. Good times.
Cheers, |
least common denominator
You were/are shooting .22 rim fire out to 100 yards!?!? What firearm do you use to get that kind of range?
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
