Have you tried fire? Uncover the root ball, pour a little diesel on it and let it burn....
Old 06-14-2018, 11:16 PM
Just plant some bamboo there. It will take over the tree and kill it.
Old 06-15-2018, 05:41 AM
copper nails.
Old 06-15-2018, 07:34 AM
I'm pretty sure this is a solution that Vash could get behind!
Old 06-15-2018, 07:38 AM
vash's Avatar
haha..
poof! gone
Old 06-15-2018, 07:39 AM
Aragorn's Avatar
If it was a stump, you could drill a few large holes and fill with epsom salts and cover. Dries it out and makes it easy to remove. Watched a handyman cut down an eight inch water maple tree with his chainsaw. Got out his circular saw and cut a cross-hatch pattern and filled it with epsom salts and covered. A few weeks later he came back and spent a few minutes prying the softened dried roots and stump out of the ground with minimal effort.
bunch of random cars and bikes.
Old 06-15-2018, 08:08 AM
vash's Avatar
SOB.
Still at it. Recent rain sent a bunch of shoots up. im thinking about moving out..to the desert.
poof! gone
Old 10-04-2018, 05:13 PM
SOB.
Did you use the Tordon RTU?
Old 10-04-2018, 05:26 PM
vash's Avatar
No, amazon wouldn’t ship to me. Maybe it was tractor supply.
I’m gonna bring some back from AZ.
poof! gone
Old 10-04-2018, 06:05 PM
OK, I think you'll find it will do what's needed. If I can be of any further help, please let me know.
Good luck, Cliff...
Old 10-04-2018, 06:11 PM
vash's Avatar
Good luck, Cliff...
So scrape a wound in the root and spray? Or drill a hole?
poof! gone
Old 10-04-2018, 06:44 PM
Platinum Member
dad911's Avatar
Try copper nails.
If driven into the trunk, they will kill a tree.
Old 10-04-2018, 07:08 PM
vash's Avatar
Originally Posted by dad911 View Post
Try copper nails.
Okay. I’ll piss on a shark plug if I thought it would help
I have some copper spikes. I tap a dozen into the root run to test. Thanks.
poof! gone
Old 10-04-2018, 07:55 PM
Ideally.....chainsaw across the top of the stump where the shoots are emerging...sawing them off while at the same time leaving open a fresh generous area for you to spray with the Tordon.
I use one of those small handheld spray bottles you can buy for a buck. Or you can brush it on. They give you a little nozzle with the product that you can also use.
If you don't have access to a chainsaw, you can use a pruning saw or even a sawzall to put some gashes into the stump where the product can get into the cambium layer.
Hopefully this makes sense.
Old 10-04-2018, 08:12 PM
vash's Avatar
The stump is ground down and I can’t find it. The shoots are coming up from the spread out roots. One big root I think.
I’m attacking this root.
poof! gone
Old 10-04-2018, 08:16 PM
OK, do the same thing to that root as I described - it will work. Good luck!
Old 10-04-2018, 08:40 PM
vash's Avatar
About to try to pee on a spark plug.
poof! gone
Old 10-05-2018, 02:47 PM
YouTube is full of tree stump how-to's.
Old 10-05-2018, 04:52 PM
I'm just gonna wait for Cliff's...his "Bamboo kicked my butt" video is epic
Old 10-06-2018, 01:19 AM
