Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Lowering the seat rails
I tried this on the technical board with no luck; therefore, I will try it here...
I have an 83 SC CAB and I am replacing the interior--including the seats.
I have a pair of 2-way power from an 86. all is good except that I sit a little too high (as in staring into the visor).
I want to lower the seat rails (about an 1") and actually move them back about an 1" but I can not find anyone to perform this for me.
some have declined due to the fuel lines running through the center tunnel...etc.
I am open to suggestions or if anyone knows someone one in So Cal (LA and south) who would perform this task, I would appreciate it.
Brad
Brad
1983 911 Cabriolet (daily driver)
2000 ML 320 (Shared by teenagers)
2005 Pilot (Wife's)
Old 07-09-2010, 03:18 PM
dkbautosports.com
962porsche's Avatar
the fuel line does not run all the close to the seat mounting brackets . but run the car (drive it) untill most of the fuel is gone drain the rest . remove the seat brackets and reweld them were you want them .
Old 07-10-2010, 04:34 AM
Problem is that I do not have welding experience which is why I need someone to do it.
Old 07-10-2010, 04:45 PM
dkbautosports.com
962porsche's Avatar
other than my self . i can think of about 4 other shops that would do or have done that job . i would not know why a shop were you are would not do it . stop by for 200 bucks i will do the left and right sides for you and repaint the area in a semi gloss black to match the rest of the pan . your only 4000 miles away !
Old 07-10-2010, 06:54 PM
Fuel lines are clipped very close to the driver's side inside tunnel....and they are made of plastic. So...the danger is there because 1.) yes...it *is* that close and 2.) it's plastic and can't take welding heat . How can people say it's not a problem?........
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-18-2010, 01:50 PM
When I did this in my race car, the fuel lines did melt. We cut the seat rails off and welded a support brace that runs between the sill and tunnel. I'm not sure we could have avoided it the way we went about it. Depending on where you weld you might be able to avoid it. I would think someone like TRE Motorsports would be a good option to do the work.
TRE Motorsports
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 09-18-2010, 04:54 PM
Those plastic fuel lines are likely to get damaged if you try and weld to the tunnel. This thread shows an interesting alternative that looks promising:
No weld to tunnel seat lowering
Old 09-18-2010, 07:26 PM
amjf088.... great post... I was trying to find that post about using nutserts.... good find.
Pictures are always good----> Need help with fuel line install - '88
...........and read the text that you are viewing a tunnel that is cut out and is place upside down on the ground....so the labels are mirror-image opposite when viewed in the upright, installed condition, as someone on that thread mentioned. Fuel lines run, IIRC, in the drviers conduit, awfully close to the driver's side vertical wall of the tunnel...and clipped too, IIRC.
Wil Ferch
Old 09-19-2010, 05:08 AM
remember that any solution that you come up with needs to withstand significant force in an accident. In the non-weld method, those appear to be pretty small bolts into 18 gauge sheet metal. No thanks.
Sean
NASA GTS2
Old 09-20-2010, 05:33 AM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Subscribed
Henry
Old 11-07-2010, 07:26 AM
boomerang's Avatar
i ended up with new lines when my guy did my seats on 80 sc
spark got into tunnel put a hole in the line
not a happy camper big job to replace
tull
87 cab
80sc Targa track car
73 project
Old 11-07-2010, 03:21 PM
dkbautosports.com
962porsche's Avatar
wil wanted to know how can any one say its not a problem ?....... you don't mig of tig weld it !!!!!!......... and if you realy think your going to burn some thing you remove it or shield it from the heat . this maybe new to some resistance weld it ??? resistance welding can be done from top side and bottom side or top side only keeping the welding tips 3 inches or more apart . it has very little heat on the back side of a panel and the heat is concentrated to a spot about 1/8" size things like plastics will not get burned .
Old 11-07-2010, 05:46 PM
