-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   The Beginning of another project - 911 SC NB RS (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/707770-beginning-another-project-911-sc-nb-rs.html)
wachuko 01-11-2016 07:37 PM
Took out the rest of the parts that need to be powder coated.
Cleaning these two was a pita!
http://i151.photobucket.com/albums/s...ps5span9gf.jpg
http://i151.photobucket.com/albums/s...psvijqdnuz.jpg
http://i151.photobucket.com/albums/s...psev1bwerc.jpg
http://i151.photobucket.com/albums/s...ps7un26ylc.jpg
http://i151.photobucket.com/albums/s...psobcelrej.jpg
http://i151.photobucket.com/albums/s...ps8iyliejn.jpg
http://i151.photobucket.com/albums/s...psuduv6qg0.jpg
And the rest of the parts...
http://i151.photobucket.com/albums/s...psrkm583xe.jpg
http://i151.photobucket.com/albums/s...psqvehev4z.jpg
wachuko 01-12-2016 04:50 AM
As it sits in the garage this morning... parts left at the local powder coating place (BNJ Powder Coating).
http://i151.photobucket.com/albums/s...pseemusgw4.jpg
http://i151.photobucket.com/albums/s...psfkmhpeh4.jpg
With the front strut supporting mount removed, I will need to scrape all that rubberized gunk out... I have some paint left, not sure if I will paint that back to the color of the car or just use some semi-gloss black in the area (masking the rest, of course)
http://i151.photobucket.com/albums/s...psurb76zcm.jpg
http://i151.photobucket.com/albums/s...psrshbtlfj.jpg
cknaak 01-12-2016 09:50 AM
cool, project! looking good.
wachuko 01-14-2016 07:39 AM
Thank you!
On other news. Powder coating parts are done! On my way to pick them up. Also a few boxes from Pelican arrived today as well... the rest should be here in a day or four.
wachuko 01-14-2016 09:09 AM
:) - I should be able to work on installing some of this back on Monday
http://i151.photobucket.com/albums/s...pss0tmv5af.jpg
seanscandalous 01-15-2016 01:53 PM
Following! This is awesome.
wachuko 01-18-2016 08:01 AM
Thank you! Looks like all the parts came in while I was out this weekend. :thumbsup:
Time to work on the car again! Here, a photo after taking everything out of several boxes and placing just the parts in a single box... now to the garage!
http://i151.photobucket.com/albums/s...pspq52tpad.jpg
wachuko 01-18-2016 08:17 AM
And unpacked all the powder coated parts...
http://i151.photobucket.com/albums/s...pseej12t9k.jpg
wachuko 01-18-2016 08:53 AM
Humm... Ordered what I thought was the correct torsion bar but it looks nothing like the original... calling Pelican.
http://i151.photobucket.com/albums/s...psph2ompie.jpg
http://i151.photobucket.com/albums/s...ps3z0lze7s.jpg
http://i151.photobucket.com/albums/s...psst386bsm.jpg
Strange because the part number in the box and the description all points to the correct part, but no way this can fit where the old one is... Here, it has two labels...
http://i151.photobucket.com/albums/s...psrmwx4yto.jpg
http://i151.photobucket.com/albums/s...psfqarbmam.jpg
wachuko 01-18-2016 09:26 AM
Looks like I got 27mm rear torsion bars
http://i151.photobucket.com/albums/s...psn5u1thgj.jpg
Too bad these are not 28mm or I would have kept them for the rear...
wachuko 01-18-2016 10:41 AM
This was easy... Elephant Racing Strut Top Camber Plate Bushings
http://i151.photobucket.com/albums/s...psv6nmmxs8.jpg
http://i151.photobucket.com/albums/s...pskbh88sbr.jpg
http://i151.photobucket.com/albums/s...ps1tlgh1d8.jpg
Mounting the ball joints
http://i151.photobucket.com/albums/s...pswkdxqcru.jpg
http://i151.photobucket.com/albums/s...ps15pcmlnw.jpg
I will install the other bits later...need to check what the torque value is for that nut...
Also installed the rubber bushing in the a-arms.
http://i151.photobucket.com/albums/s...pssoone43v.jpg
wachuko 01-18-2016 11:50 AM
I think that I need to wait for the instructions of the torsion bars to find out the correct angle for the bushings?? I need to look at the book... let me insert the bushings while I get the book...
http://i151.photobucket.com/albums/s...ps0ibghokt.jpg
http://i151.photobucket.com/albums/s...pswgafzcoq.jpg
http://i151.photobucket.com/albums/s...pspadgmhng.jpg
wachuko 01-18-2016 05:20 PM
Removed all the gunk from the shock tower area... painted it flat black on top and underneath to protect it from rust.
http://i151.photobucket.com/albums/s...ps1bgmbiff.jpg
http://i151.photobucket.com/albums/s...ps2lqizlim.jpg
http://i151.photobucket.com/albums/s...psjctgfnuw.jpg
http://i151.photobucket.com/albums/s...psbyjhgcrj.jpg
http://i151.photobucket.com/albums/s...pscdlv9lxp.jpg
Removed steering rack. Forgot to order the rubber bushing with the bearing inside...will order tonight with a few more things... Removed the tie-rod ends from the rack.
http://i151.photobucket.com/albums/s...psvg1lujgo.jpg
http://i151.photobucket.com/albums/s...ps5oydmtcl.jpg
http://i151.photobucket.com/albums/s...pse4i2dck4.jpg
Installed the mesh and frame at the end of the hood...used the wrong screws but those are just in there until the correct ones arrive.
http://i151.photobucket.com/albums/s...pssdikx30k.jpg
wachuko 01-19-2016 05:55 AM
Only held in place with one bolt... will align it better, and install the other three bolts, tonight after work...
http://i151.photobucket.com/albums/s...psglem6zrp.jpg
http://i151.photobucket.com/albums/s...psgnbgxyzx.jpg
Also forgot to mention that I got the original rubber gasket for the fuel sending unit and it worked like a charm... sometimes the best part is the original part... the gasket that was in the boxes of parts that came with the car would not align correctly :rolleyes: . New nuts and washers are on their way. I have a new plug cover... forgot to get this one to powder coating. I will just install the new one that I have in yellow zinc finish.
http://i151.photobucket.com/albums/s...psb5kgakeg.jpg
wachuko 01-23-2016 12:09 PM
Can't do much until the rest of the parts get here...so baby steps. Installing the spacer on the strut mount.
http://i151.photobucket.com/albums/s...psxvmkfiyf.jpg
http://i151.photobucket.com/albums/s...psbtnspcyo.jpg
http://i151.photobucket.com/albums/s...psmbo37lt0.jpg
Rinse and repeat...
wachuko 01-23-2016 03:00 PM
These are done...
http://i151.photobucket.com/albums/s...pseshoi5rr.jpg
http://i151.photobucket.com/albums/s...psyagtfcpv.jpg
wachuko 01-23-2016 08:27 PM
For a minute there I thought the hubs were painted black... It is all accumulated brake dust...
http://i151.photobucket.com/albums/s...psexxitrxh.jpg
More cleaning left to do... I should have used the soda blaster to begin with...
http://i151.photobucket.com/albums/s...psrg3xmubl.jpg
I waste so much time installing parts just to look at them...
http://i151.photobucket.com/albums/s...psxg2a3xln.jpg
wachuko 01-24-2016 06:32 PM
Preparing the hub for the bearings...
http://i151.photobucket.com/albums/s...psghhjjior.jpg
I am doing my own yellow zinc with the bolts I buy locally... Sumerge the bolt into the prep liquid, wait 20 seconds, rinse in clean water, dry with heat gun (to avoid the wait), and voila!!
http://i151.photobucket.com/albums/s...psp16auu2e.jpg
http://i151.photobucket.com/albums/s...ps5gbxdwoa.jpg
I did not know that the hub were specific to sides... These were marked as such...
http://i151.photobucket.com/albums/s...psgwuqeuxb.jpg
http://i151.photobucket.com/albums/s...psosilurxl.jpg
http://i151.photobucket.com/albums/s...pszjok8pub.jpg
Done! (well...still need to install de grease cover)
http://i151.photobucket.com/albums/s...ps5s4t8pfm.jpg
wachuko 01-25-2016 05:28 AM
Originally Posted by amber lamps (Post 12955692)
Very nice. Tell me about the zinc process and sorce for the kit. I'd be interested in that as I am sure others would be.
Just to be clear... I am only using yellow chromate to get the finish on new zinc plated bolts that I buy locally... Yellow zinc plating is a two part process... first you zinc plate the bolts and then you run them by a solution that gives it the color.
When I ordered the zinc plating kit from Eastwood (btw, this is still in the box and have not used it...) , I also ordered some yellow chromate from Caswell... ...mixed some distilled water and 2 oz of this product....
http://i151.photobucket.com/albums/s...psc8b4506c.jpg
I felt like I was dealing with plutonium...this came inside two boxes, and then the can was in a sealed bag...
http://i151.photobucket.com/albums/s...ps0aa092df.jpg
http://i151.photobucket.com/albums/s...ps99059f54.jpg
http://i151.photobucket.com/albums/s...ps03ea9c5e.jpg
Let's try a few parts... those new nuts look clean...
http://i151.photobucket.com/albums/s...ps38d089f1.jpg
http://i151.photobucket.com/albums/s...ps47c8875d.jpg
http://i151.photobucket.com/albums/s...ps63e202f3.jpg
Rinse with clean water and dry with a heat gun at low setting...
Does not work on anything but newly zinc plated parts...
Ferrino 01-25-2016 04:51 PM
Cool find on the chromate solution! How do the parts look next so factory zinc/cad plated stuff? I guess it depends on how long you soak for and the original plating. They look good to me!
Very nice way to treat fasteners from the hardware store and those annoying Porsche parts that don't get the yellowing treatment.
