Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Easiest way to strip door jams without blasting?
Was wondering what you guys use to strip things like door jams if your not blasting.
Old 07-11-2015, 12:45 PM
Fixer's Avatar
i usually simply sand enough to prime and paint.
why do you have to strip it to bare?
Are there multiple paint jobs?
Matt
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 07-11-2015, 07:26 PM
dkbautosports.com
962porsche's Avatar
what matt said !
if you really need to strip it you could use a mini 3" DA with 80 grit .
Old 07-12-2015, 06:13 AM
Paint has cracked and there are some surface rust areas.
Old 07-12-2015, 08:16 AM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
Photos would help, but start sanding and see what you got. Everything down to bare is unnecessary though
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 08-02-2015, 06:25 AM
dkbautosports.com
962porsche's Avatar
if the paint is cracking and you have rust then mask off the hole jam on the back side of the pinch weld with duck tape and old bed sheets so no sand will get into the car . get one of the little hand held spot blaster and some fine 001 sand then blast the finish off . you could sand it off with 80 grit on a da but it will not remove the rust . just blasting every thing will give you clean metal to work with .
Old 08-02-2015, 04:37 PM
Cairo94507's Avatar
Definitely tape everything off extremely well or you will be finding sand for years.
'71 914-6 #0372
'17 Macan GTS
Old 08-03-2015, 07:10 AM
Use aircraft paint stripper, brush it on, use a putty knife and scrape it off.
Old 08-03-2015, 11:00 AM
Thanks for the ideas.
Old 08-03-2015, 03:55 PM
I use a wire brush on a drilling machine to bring that area to blank iron. Works easily with perfect result.
Old 08-18-2015, 12:00 AM
