Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Help to find where these bits sit?
Ih , Can anyone show me where these bits fit?
I inherited this 64 SC 100% pulled apart so it is a massive gig-saw puzzle?
Old 10-24-2014, 03:19 AM
They are air duct plates that fit under the cylinders. The springs hold them in place and are attached to the drain tubes. Obviously there is a left and right side.
Old 10-24-2014, 06:18 AM
Hi Matt, Thanks for that.do you or anyone have a photo?
Old 10-24-2014, 06:31 AM
Can't find a photo, but they fit up against the cylinders, above the pushrod tubes, and between the case and the head. Left and right are different to fit over the bolt head on one side and the acorn nut on the other. The wire clips fit over a pushrod tube to hold them tightly in place. The heads and pushrod tubes must be removed in order to install these air guides.
The Cap'n
Old 10-24-2014, 02:35 PM
Go to the Stoddard website under engine cooling and you'll find them there...
Old 10-29-2014, 06:36 AM
