How to fix a broken aero mirror base
When I took my aero mirrors off to get the car painted I accidentally broke one of the two locating tabs off the base of the drivers mirror. After getting over being mad at myself I took a close look at options. The tabs are relatively soft pot metal so I figured I had nothing to lose trying a repair
Located the center of the broken piece, drilled a small pilot hole about 1/4” deep, being careful to keep the drill bit as centered as I could. Followed that with an 1/8” drill bit. Got out my tap set and tapped threads into the drilled hole. Sorry, don’t recall which size I used, but I’d selected it to work with a metric screw I had. Ran the screw into the hole to verify it would work. Pulled the screw back out to put 2 layers of heat shrink on the exposed threads. Ran the screw back in with some red Loctite. Mounted the mirror like nothing had ever broken. ![]() ![]()
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
