Andial Twin plug with No Spark! Need Advice!
84 Carrera was idling just fine and then it just died. There is no spark, however I have 12v coming in at the 2 ignition coils. There is 12v (with ignition switch in on position) coming in at the Andial splitter under the drivers seat. Need help bench testing the actual Andial signal splitter since Im pretty positive it is the problem since I have 12v coming in at the splitter. I think the splitter isnt sending a signal to the 2 coils if i had to guess since Im getting the 12v at the coils but no spark to the plugs. Anyone have experience testing these Andial signal splitters?
Old 07-01-2018, 10:54 AM
abit off center
cgarr's Avatar
You did nothing else while it was running, it just quit?
______________________
Craig
G2Performance
Old 07-02-2018, 08:45 PM
T77911S's Avatar
what about the CPS or reference sensor.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-03-2018, 04:22 AM
It was idling and then it just quit. I did nothing.
Old 07-03-2018, 09:57 PM
Yes that is the next thing I will check
Old 07-03-2018, 09:58 PM
fred cook's Avatar
Try cranking the engine while watching the tach. The tach should register at least 2-300 rpms if the crankshaft position sensor is working. If there is no movement of the tach needle, the CPS sensor is probably bad. I had the same problem with a Jaguar several months ago. Took me a while to figure it out! Good luck.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-04-2018, 05:24 AM
