Andial Twin plug with No Spark! Need Advice!
84 Carrera was idling just fine and then it just died. There is no spark, however I have 12v coming in at the 2 ignition coils. There is 12v (with ignition switch in on position) coming in at the Andial splitter under the drivers seat. Need help bench testing the actual Andial signal splitter since Im pretty positive it is the problem since I have 12v coming in at the splitter. I think the splitter isnt sending a signal to the 2 coils if i had to guess since Im getting the 12v at the coils but no spark to the plugs. Anyone have experience testing these Andial signal splitters?
Thanks Last edited by ourv12; 07-01-2018 at 11:23 AM.. |
abit off center
You did nothing else while it was running, it just quit?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
what about the CPS or reference sensor.
Try cranking the engine while watching the tach. The tach should register at least 2-300 rpms if the crankshaft position sensor is working. If there is no movement of the tach needle, the CPS sensor is probably bad. I had the same problem with a Jaguar several months ago. Took me a while to figure it out! Good luck.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
