Need some help with shorted parking light wire
I have an issue with my '85 Carrera, I have narrowed it down to a short to ground on the wire (grey/black) leading from the bottom of fuse #4 (left side parking lights) to the rear signal light housing. There are two wires leading from the bottom of the fuse, one to the front headlights, and one to the rear signal light. The one leading to the front is OK. Disconnected the wire from the fuse panel and pulled the plug from the rear bulkhead to isolate the wire and it is showing less than 1 ohm to ground.
I've checked as much as I can near the fuse box and rear engine compartment but can't see where it might be running next to something that could have worn through the coating and shorted to the chassis. Anyone have idea as to how I might isolate where exactly the short is? This harness is pretty buried as it runs from the front to rear of the car... Thanks! Bill |
Fleabit peanut monkey
I swear my engine lid light wires caused the left side parking light fuse to pop. (they were unattached and touching engine)
That was on an 81. Unplug and see if fuse blows. I also read where the light itself can short to ground in my searches (in the way back)
1981 911SC Targa Last edited by Bob Kontak; 07-08-2018 at 03:15 PM.. |
ROW '78 911 Targa
Engine lid light plugs in at rear male 6 pin connector. Try unplugging it and Check ohms again.
Bill |
ROW '78 911 Targa
I am talking about the single connector on a short grey wire coming out of the male 6 pin connector. It is the power supply to the hood light. Comes off the running lamp circuit in the 6 pin connector.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-08-2018 at 05:12 PM.. |
Short
Did you remove the bulb? Check the socket? Isn’t the plate light circuit in there too?
ROW '78 911 Targa
Plate lamp is on a different circuit, unplugging the rear male 6 pin takes the bulbs out of the circuit.
I did pull the bulbs and check the copper connection that the bulb makes contact with. When I pulled the 6-pin connector it showed an open circuit so I believe the wiring inside the tail light housing is fine. Bill |
Bill |
Darn, you guys are good, mystery solved with all your help. Turns out that when I installed the new engine compartment light I reversed the ground and +12V wires. When I had the light hanging in the air it worked fine, but screwed it to the lid the ground side (to which I had my +12V) is meant to make contact with the lid mounts which are ground. Reversed the wires and everything is working fine now. When I installed the light housing a while back I knew it didn't work, but didn't get around to debugging it until now. I also didn't notice that the left side tail lights were out until recently, so didn't make the connection.
NEVER would have thought to look at that light if it weren't for your suggestions, so thanks very much! Bill |
ROW '78 911 Targa
Glad you found it. Not sure about the connector location for the hood light on the ‘85. So far I have stayed away from the ‘84 and newer body harnesses. (Plan on keeping it that way for now as they are full of NLA unique connectors.)
