Can you tell what size the wheels are, without taking the wheels
off of the vehicle? People like to guess, but I want to know if there is another way instead of jacking the car up and taking the wheels off.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
Hi, if you post a picture i can tell you what size the rims are ..if that is the Q? Of course it must be Fuchs...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
as Ivan indicated, 16x6, 16x7, 16x8 and 16x9 inch fuchs each have unique features that make it relatively easy to distinguish from fotos -- suspect the same can also be said for 15" fuchs . . .
PM sent.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
It's best to pull the wheels and look
for a '76 Carrera oe std was 6 & 7 x15 185/70 & 215/6 option1 was the same tires on 7 & 8 option2 was 7 & 8 w/ 205/50 & 225/50 tires your picture appears to show 7 & 8, probably option 2 tires but hard to tell from here
The tires read 205/50 & 225/50 ZR 15. The ZR 15 is what?
One last question in regard to the finish on the fuch wheels. Does anyone have a pic of what the Turbo finish and the outer barrel polished and then (milky clear) anodized looks like?
Z speed rating
R radial 15 wheel diameter |
When I took a tape measure, the wheel measured 16, that's why I am asking. This is confusing.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 07-11-2018 at 04:40 PM.. |
Nice looking car you have there BC
I imagine you are measuring the lip, not the the actual wheel diameter.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
What does the tire say????
Option 2 was a one year only choice that was the most efficient every offered.
I am in the process to restoring the wheel to originality. Doing it myself. Bill, this is what I have been told: First, the spokes anodized and the outer rough offset with the smooth lip. (similar to the 74-77S but wider wheels) Second, the center black with the outer rough offset and smooth lip. (like 75 Carrera USA) Third, the center black with the offset and lip smooth. (Like 75> Turbo and all 16" wheels) I want to do the third option but I don't know what the finish looks like. What is the Turbo finish that has the outer barrel polished and then (milky clear) anodized? This became available as a option in 76 but very few had them.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 07-12-2018 at 07:23 AM.. |
Thread Tools | |
Rate This Thread | |
