Jonny H's Avatar
^ Hey, no worries. What was the amp draw?
www.classicretrofit.com
Old 07-22-2018, 11:40 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by kuehl View Post
More humble than a round at Carnoustie in Dundee .
Just watched a youtube vid on Carnoustie's course layout. Can you say 125?
1981 911SC Targa
Old 07-22-2018, 01:09 PM
rokemester's Avatar
Originally Posted by HaroldMHedge View Post
Here are photos of my 87 911 Carrera W-Germany A/C Relay.
I thought some of the pics I took earlier this year when I was messing with my AC among other things. I was wondering where the heck the AC relay was in the smugglers box! Going back through my pics I found it. I find it helpful to shoot several shots wide and tight at least for a frame of reference.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 10-01-2020, 11:09 AM
I ran into same problem. A/C worked fine in the morning, but on way home from work temps at 105 degrees. First check fuses all good then check A/C compressor relay, it was good. Next did a jumper wire on Compressor clutch relay plug 87 to 30. Should of heard clutch clicking. No click. Check wire for power all good. Ended up changing compressor clutch coil. It was fried. All works great now. Good luck!
Old 10-01-2020, 04:45 PM
Is anybody is still watching this thread?
I'm in the middle of a total A/C revamp using Kuehl componennts.
My smuggler's box relay appears to be bad and I have ordered a new one, but I have a question about the schematic.
1986 911 turbo
My terminal 87 is always + 12V NOT terminal 30, as described above??
When the key is on, 86 has 12V, which should close the points in the relay.
If the relay was functional, it would allow 12V on 30.
The wire leading from 30 goes forward to the A/C switch in the console.
Am I on drugs again, or did Porsche change the wiring?
I think the current wiring will function, but it bugs me to have a deviation.
I don't think I have a factory schematic for turbos beyond 1977.
terry
1986 911 turbo - less than 30k miles
Old 07-17-2021, 06:47 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Schematic.
1986 911 turbo
terry
Which one?
Factory, or aftermarket?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-17-2021, 07:23 AM
Factory A/C until now, with factory relay.
Questioning the schematic in this thread.
BTW, also factory delivery and retired engineer
Old 07-17-2021, 07:45 AM
Contact info.
pm me.
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-17-2021, 08:05 AM
Follow-up info.
The 87 and 30 pins on MY smuggler box relay ARE reversed from the wiring diagram.
Not sure why they deviated from the diagram, but the new relay works and so does the evaporator blower.
The reversal just made it hard to diagnose the bad relay.
Thanks to Gerry above for sending a wiring diagram and helping me understand it.
Old 08-03-2021, 04:50 AM
echecsqueen's Avatar
Tagging this thread
Old 09-22-2021, 07:47 AM
also tagging this.
I just spent a couples days chasing an issue with the Griffiths system AC on my 89.
The root cause was my fault.
You can read more details on the other AC thread I started.
Sold: 1989 3.2 coupe, 112k miles
Old 09-22-2021, 04:34 PM
kuehl's Avatar
Henry,
I would not say the cause was your fault.
It was who ever before you tossed in that funky AC relay.
Enjoy the rest of the warm season rides,
Griff
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 09-23-2021, 05:13 AM
