theiceman's Avatar
As jonny pointed out, this is what it should look like.
don't mind my straight edge, its just something I grabbed.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-24-2018, 10:11 AM
So your alternator fits all housings? A bearing broke today so i might add a retrofit alternator to my CDI order
Old 07-24-2018, 11:51 AM
MBAtarga's Avatar
OP, what is the housing casting number on the top?
Mark
'83 SC Targa - since 5/5/2001
Old 07-24-2018, 12:00 PM
Just replaced the housing on my 86. It was cracked. In any case I bought a magnesium housing from Germany and they sell different spacers to fit behind the alternator for different alternators. The 65 amp one is a different size than a 95 amp one. You may have a mix and match. I really had a hard time fitting my housing over the notch at the base, but I think I got it right, it all lines up. The pulley spacers have nothing to do with it, they are only for tightening the belt.
Can not wait to light up the old housing! My son in law made a magnesium powered small boat that fed water to the magnesium fire to power the boat, but I digress. I was afraid to buy the host's aluminum housing because I did not think it would be as strong as the magnesium one, it is probably good.
Old 07-24-2018, 12:16 PM
Pulled it all apart today, since a bearing is starting to make noise. It is a 50amp alt and the measurements for the housing is as shown in the photos.
Have to make the choise of either going original and change the housing to the correct one, refurbing the alternator and clean up the fan ... Or leave the housing as is, change alternator and clean up fan 🤔
Alternative is as said above - do a spacer that fits behind the alt and move it forward.
Also I think the fan needs a new center 🙄
Old 07-24-2018, 01:18 PM
fred cook's Avatar
If the bottom of the alternator is not properly seated against the mount, it will cause cracks to form in short order. Check the numbers on the alt mount to make certain it is the correct one for the car. The original may have been damaged and replaced with whatever was available. I believe the answer to the problem will be a replacement alternator and/or housing!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-24-2018, 01:44 PM
[QUOTE][So what about a plate or large ring of somekind that sits behind the alternator between it and the housing. Not unlike a wheel spacer that just sit where it mounts flush, then just some longer alternator mounting screws. Might be able to do it for a few bucks and some time until he /QUOTE]
I just had the alternator out of my 1975. There is a spacer that sits between the alt and the fan housing. I didn’t think anything of it at the time, and didn’t take any pictures of it. It looks to be about the right size, maybe 1/2 inch.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 07-24-2018, 06:18 PM
911 65-74 (using 22MM Spacer)
911 75-83 (using 11MM Spacer)
The picture shows it behind the fan housing, but I think it goes between the alt and fan housing. That will leave the housing in the same place, but moves the alt rearward 11mm.
Rex
Old 07-24-2018, 06:23 PM
theiceman's Avatar
good work Walter .. great find, this looks like it is exactly what OP needs along with some longer bolts.
Old 07-25-2018, 05:13 AM
Thanks for all the helpfull input! yesterday the bearing in the alternator broke too, and one of the screws - so I think Im going for a new alternator, which might be a retrofit now that I have it all pulled apart.
Old 07-25-2018, 06:03 AM
puddy's Avatar
I'm very sure my alternator belt is on a similar angle to the OP, it just misses the housing on the bottom. Is this really a problem? I've been running strong for over 4 years plus the previous 15 years from the previous owner.
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 07-25-2018, 06:37 AM
Old 07-25-2018, 07:00 AM
Hi Puddy! - I think my car has been running like this for some years, but I did find 3 used belts in the car - It will wear the belts more. I think the angle is a bit more harsh on the bearing in the alternator too.
Old 07-25-2018, 07:03 AM
theiceman's Avatar
look how long those bolts are. can definitely put a spacer in there.
Old 07-25-2018, 07:22 AM
al lkosmal's Avatar
alt chart
Here's an alt/fan chart to help you determine if the combo you have is correct and/or will work for you.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 07-25-2018, 07:46 AM
Harpo's Avatar
Opps posted in wrong location
Old 01-01-2019, 05:29 AM
