Another windshield seal thread...
So I was caught in a down pour on my way home from a company car show, and was taken aback when water began to drip from between the dashed and glovebox surround.
Some research suggested new windshield seals... alas after reading through many thread about URO's "new" design and Factory Porsche seals, and DIY or have a pro do it I am as confused as when I started. Part of me wants to DIY as I can check for any corrosion that may have occurred. But I am also lost on what seals to use... my gut says Porsche Factory, but URO's new design looks pretty nice. |
Mine leaks at the drivers side corner and drips into the door side pocket. Ive put up with it because ithe car usually only sees rain once a year and garaged when resting. I think Ive read every thread on this subject and the ultimate solution is 993 seals and windshield with the 964 seal and windshield being close second. This is assuming you have black trim of course. I finally made a decision and ordered the Porsche 964 OEM seal and will put a 964 windshield in. Same procedure as the original only you dont have to deal with the aluminum trim in the middle of the rubber seal. I would have gone the 993 route if I knew of a local windshield guy who could think outside the box. Also contemplating the 3M bedding and glazing compound for a little extra insurance.
wait... use a 993 or 964 seal on an SC? same size glass, etc?
Mine has been installed all wrong for years. I think that flappy part should be out, but it's tucked in with goo in there, too. This will not be pretty. Can I remove the nice glass and re-seal without damaging the glass? This has been one of those, gonna do it some day jobs.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Fleabit peanut monkey
Does lost mean fearing the spending of an extra $70? Just talking as I did not look prices up. Once you get into the process you will find the work is simple grunt work. Cut out the metal trim with a box cutter, glass still in place is the hardest work, maybe. Get window out. Assess the rust damage. Fix it. This may/can be the most work. Warm up seal in hot water, place on windshield on a bench and struggle placing trim in. It sucks but not that bad. Now the easy part. Get fat speaker wire or a really stout tiny rope. Stuff it into the flappy thing and grease with glycerin or KY or soap of your choice. Mr Muscle pal pushes down on windshield from outside as you pull the wire out bringing lip over the metal body lip.
1981 911SC Targa |
Senior Member
R&R-ing your front glass is pretty easy. I have heard MANY people, including and especially glass guys, say you should spring for the OEM gasket. You can use the glass as a template for shaping the metal trim. Do this. Make sure the trim is fully engaged into the gasket (the trim has a 'hook' that locks with the gasket). Put silicon spray on the gasket and rope it in. Easier than you think.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
The cost isn't an issue, I was just wondering if people found the NEW URO seal to be better than the Porsche part. There is just a lot of discussion on the seals, from 993 full replacement to URO I was just trying to get my head around the best option.
Brew Master
I don't recall what seal I put in my car. I'll see if I can find the invoice for it and post back. As for DIY, the main thing is, don't mess up the metal when you remove the windshield. I installed my own with the help of my son and had never done one before. Just take your time and it goes pretty easily.
Before you write off the existing seal you should check your corners which is where many need to be adjusted even after being replaced. I made a plastic tool to move the upper and lower corners back into place occasionally. I use a rubber mallet and the plastic "punch" against the metal trim which helps keep the rubber in place. There are a lot of threads on adjusting the window seal. The only reason I replaced my seal is I removed the windshield when I was having the car painted. Try adjusting the seal first and then test with a hose. It might save you some time and money. |
I had that same kind of leakage on my '72. When I removed the windshield and dash cover, I found the whole area under the corner rusted out.
Marv Evans '69 911E |
Well lets hope thats not the case here... I'd hate to have to burn the car to the ground...
Don't know if you have found this thread on replacement of the windshield seal with the new URO version, but it seems that "3Ddesigns911" had a very successful experience with the new URO seal. Check it out.
I am soon to replace my seal and have a Porsche factory seal on hand, but I am considering buying a URO one after reading about the posters good results. His installed pics look much better than even the Porsche seal. Re-designed New URO Windshield Seal Review
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
My opinion: that URO new seal looks too wide. Kinda looks fat, cheesy and non-Porsche, but I've got too much of an eye for these kinds of things. Spring for the Porsche seal, you won't regret it.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Yea, I usually will error on the side or Porsche parts. After all is has last 36 years so far.
Coram Deo
I went with the Porsche seal and am very happy with the results. I haven't smeared in the glazing compound yet, but that's belt-and-suspenders level of protection.
My windshield did have a bit of rust in the bottom passenger corner. See it here: SC Windshield / targa window seal replacement and trim refinishing How does your trim look?
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Cool, I was reading through your thread the other day.
