Runnin on empty
Another H4 trim question
Hi all,
Both of my H4 trim pieces look like the pic below. Should they have an exposed screw head? Am I correct in assuming that both trim pieces are missing the outer screws in the dual screw setup? I ask because want to take them off and affix them correctly. Thanks
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
the thread is M5 -.8 thread pitch as an alternative you can get a couple of button head M5 -.8 bolts ~20-25mm long and a plastic washer. The Hex head makes it easy to use a wobble key. This makes it easier to snug up than w/ a screwdriver.
Runnin on empty
Thanks Bill. I’m big fan of button head screws and bolts. I like your idea. Sent from my iPhone using Tapatalk
Thread Tools | |
Rate This Thread | |
