Remove alternator belt without pins in the pulley
New belt comes tomorrow. My pulley does not have the holes for the tool to hold it in place.
Am I missing a part here?
Old 08-27-2018, 07:08 PM
steely's Avatar
Doesn't look like mine - that looks like it was cut from a fan.
What year?
Others will chime in.
Mine (PN 93010620902) looks like this:
I'm in Horsham BTW
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-27-2018, 07:46 PM
steely's Avatar
Just in case, and perhaps you are aware already, but please don't stick anything into the blades to stop it from turning as you wrench lest you risk busting them.
We gotta get you an answer.
Dan
Venetian Blue
Old 08-27-2018, 07:50 PM
Your pulley uses this, available from our host:
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 08-27-2018, 07:59 PM
You need the OTHER pulley tool, P208:
https://www.pelicanparts.com/More_Info/PELPWFPW.htm?pn=PEL-PW-FPW&SVSVSI=911M
https://www.pelicanparts.com/More_Info/PELTOLP208.htm?pn=PEL-TOL-P208&SVSVSI=911M
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 08-27-2018, 08:01 PM
Diss Member
Quicksilver's Avatar
You don't need a tool to hold the pulley unless the belt is horrendously loose. Grab the 2 opposite sides of the belt (between the pulleys) and squeeze them together to increase the tension. This will keep the belt from slipping while you loosen the alternator nut.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-27-2018, 08:12 PM
car is a 76.
off to order more tools .
thanks pp
Old 08-27-2018, 08:13 PM
sounds viable. belt will be here tomorrow
Old 08-27-2018, 08:18 PM
can anyone confirm if the belts are the same size. or will i need a different size belt seeing that the pulley is from an earlier year.
76 is a 725 and the earlier stuff looks like a 710
looks like the belt on there is a 740...
Old 08-27-2018, 08:25 PM
Flojo's Avatar
depends on the size of the lower pulley.
get both, the 725 and the 710, they don't cost the world,
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 08-28-2018, 12:41 AM
730 and 735 are often used with non stock pulley arrangements.
206 637 4071
Old 08-28-2018, 04:23 AM
An impact gun should also loosen that nut easily if you have one.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 08-28-2018, 04:53 AM
thank you ordering a 735 and a 740
Old 08-28-2018, 06:15 AM
Canyon Runner
70SC's Avatar
You can use a 8mm hex key to hold the alternator shaft.
Old 08-28-2018, 10:43 AM
Blake. I have pulley wrench if you would like to borrow.
Rob
Old 08-28-2018, 05:48 PM
Rob
thanks rob. ill be in touch. i think i can just hold it as an above member mentioned.
where in sepa are you
Old 08-28-2018, 06:17 PM
