Odomerter working but speedometer not?
I recently sent my speedometer to fix/calibrate because the needle was not reading the speed accuratly. I changed the speedometer cable sensor, and still the same problem.
Speed is not accurate, but the odometer is working fine?? How? From NH they said that they found nothing wrong with the internals of the speedometer. So with new speedometer cable, verified wire continuity from sensor plug to speedo back, and “good” speedometer? What could be the problem? Thanks IVan
79 SC Back to Basics! 2006 997 C2s Cabrio - Sold 1999 996 C2 - Sold |
Brando
Tire size? It’s not uncommon for speedometers to be slightly off from the factory. In fact I believe they (many auto manufacturers) make them optimistic for safety reasons.
Turbo powa! 1977 911s. it's cool |
Member 911 Anonymous
What size wheel/tires do you have? How far off is it?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Jinx ^^^ :-)
Factory wheels and tires. Is not off, is jumpy and not accurrate or strady.
It is on the low side way off., If I need to got to more than 30 mph for it to start to move and then is on the low side and jumpy, not smooth.
If you have a buddy with a speedo you can borrow/swap to make certain it is not your newly rebuilt/tested speedo would be a good idea.
Here is another possibility, when my speedo was off by 10-12% it was due to a magnet that got loose, dropped off and was sitting at the bottom of my gear box. Once re-JBwelded on, she was good but 3 mph off ![]()
One more thing, you did check all connectors behind the gauge and in the tunnel are clean and tight?
I think is the magnet inside the transmision. I will put it on future things to do if I drop the engine.
Dam it. It was out for several months, but it never occured to me to be a internal tranny problem.
Schleprock
You don't need to drop the engine to remove the differential. Access to the side cover is actually quite good with the transmission in the car.
Kevin L '86 Carrera "Larry" |
Thread Tools | |
Rate This Thread | |
