Not sure about the newer potted permatunes, but the older ones used a 100 ohm resistor in the trigger circuit which is a little on the high side for keeping the points clean. Probably not a bad idea to clean them once a year as general maintenance if using the permatune. Fred
Originally Posted by mrrolleyes View Post
car is running. thank you everyone.
i got a crash corse last night on points.
we needed to clean the points and pickup it seems like the rotor was not making a solid connection with the cap in the center. so we raised it up a tiny bit to get it to fire. new cap and rotor are ordered.
Old 09-08-2018, 04:09 AM
side note, or question..
car had plug wires with grounds. is it ok to switch to the non grounded wires? aka magnacore
also it has a bosch rotor, i think i ordered the the porsche oem one.
Old 09-08-2018, 06:04 AM
Registered Minimalist
75 911s's Avatar
I did a little more research after our conversation.
I found Peter Zimmerman noted this in an old thread "Yep, the grounded shields on CIS cars were to divert any stray sparks from plug wires to ground, rather than have those sparks travel to the plenum chamber of the airbox."
Reading on, this didn't help the airbox from exploding, so the grounded/shielded wires were done away with after 83.
In other words, you should be fine to use magnecore non shielded, non grounded wires. However and from my understanding, the solid core magnecore wires are for use on MSD ignition systems.
I should also note they look totally rad, that's why I run them! :-)
As for your rotor, aren't the Porsche OEM parts made by Bosch?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-08-2018, 06:15 AM
thank you!
Old 09-08-2018, 06:18 AM
I run the clewett wires and love em. Cleaned up my ignition and they look great too. (ie not red)
youtube.com/bennyobscene
Old 09-09-2018, 07:22 AM
75 911s's Avatar
Yo red ign wires look like they belong on a v8. Especially half dirty loose ones just hanging there like spaghetti.
Old 09-09-2018, 12:23 PM
and im back
put everything back and no start again.
borrowed a new cdi box from a member... thank you
new cap and rotor and wires..
cdi box has the hum like it should.
with key on i get NOTHING to the dizzy or coil.. also when i move the points i get nothing at all
im lost
Old 09-14-2018, 03:24 PM
checked all grounds?
Old 09-14-2018, 04:59 PM
it runs!!!!!
reading this ....'75. No spark, no power to coil.
the interior gound wire going to the cdi was the issue. fired right up like weekend and bernies.
going to test the permatune now.
Old 09-14-2018, 05:33 PM
old box works... idles fine but rough. the yellow light on the permatune has a flash every here and there
Old 09-14-2018, 05:36 PM
Wiring diagram for 3-pin
Thanks everyone for all the help. One addition I wanted to make was how to wire the CDI unit in. Like many of you, I was dealing with an old and brittle harness. What I thought was a CDI unit issue, was in fact a shorting issue in the harness. Many hours with my ammeter trying to figure it all out is what that cost me (oh yeah and needlessly buying a new Permatune unit $$$$$). Since you've all helped me, I wanted to share how to simply wire the CDI unit into you car, if like me you decide to start a new.
Good luck all.
Old 01-11-2019, 12:24 PM
