no "ignition trigger" on permatune 2.7
please bare with me here..
preface.... car was running fine. started to degrease the motor and do a little bit of cleaning and hosed off lightly, started it, turned it around and then light degrease round 2 with some more hose. mainly on the sides of the motor. this time no start... tried to kick over but no luck. let it dry over night and started this morning for a second and cut out. and a ploom of smoke and done. jimtweet being awesome has helped me over the phone as much as he can but im at a dead end for now. car has permatune and we thought the cdi box was beat. called them and they said text xyz and im getting a green light but no red (ignition trigger) im getting power to pin 14 on the harness so i know its getting power thru the alternator. im also getting power to the red on the cdi box (3 pin setup). car will turn over but its not "kicking" also there is no "whine" from the box, not sure if the perma's have that whine line the regular cdi box does. ran to the parts store and grabbed a 8202 MSD coil because some searching said that might be the issue. and NOPE still no red light. points were done about 6 months ago but might of gotten wet? TIA as usual.
And this is how you check lights when you are alone
![]() Sent from my iPhone using Tapatalk |
And who put that in?
And you checked that the points' signal varies from 12V to ground with a test light, right? If so, the box is bad, since you changed the coil and you have 12V on the middle pin to the box.
Dave |
ROW '78 911 Targa
Wet cap and points? Nah, couldn’t be that simple. Verify opening and closing of points as mentioned.
in the car when purchased 2015 date code googling how to check point signal... |
If you are not having a spark, try this:
ROW '78 911 Targa
BTW power to CDI comes to the back from a switched power fuse at the front fuse panel, not from the 14 pin connector. It then goes to one of the 3 rear fuses.
Power from engine harness 14 pin is constant power from alt, via starter, via battery and runs to a different fuse on the rear fuse panel.
well according to this
https://www.youtube.com/watch?v=IblZtEmM26E with wire on coil negative i get nothing "positive" on the test light when turning the motor by hand. |
Is this different from 3pin to 6pin CDI boxes ? |
I could try to find time to come up and help if you don't resolve this soon.
I'd throw a test light on the points signal then work backwards from there. My car had a similar issue before, and it just turned out to be bad points.
youtube.com/bennyobscene |
benny that would be awesome! points are over my head... im sending you a PM.
ROW '78 911 Targa
No difference. All switched power to CDI comes from front of car.
Using a testlight on the coil can possibly damage a CDI.
Dave |
You need to put the test light on the points connection at the distributor to see if the points are working correctly, not the coil negative. The coil negative with the CDI will be at ground potential always and your test light won't light. The video is showing how it can be done with the Kettering system with the coil negative connected directly to the points. With CDI, the points circuit is divorced from the high voltage circuit to the coil. Fred
You could take a simple square wave generator and feed a signal to the CDI. This would simulate the points signal.
something like this.....CDI TESTER SQUARE WAVE GENERATOR - IG3TECH
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
^. Or simply ground and release pin ‘C’.
www.classicretrofit.com |
yeah let me just dig out my simple square wave generator
/ˈpɔrʃə/ PORSH-ə Fan
Not exactly what you're asking, but I'll share my experience with Permatune and my '77...
After lots of intermittent problems with my Permatune -old original PT CDI and new, expensive fancy one - and points I swapped them both out for a MSD Streetfire and Petronix ignitor. Never had another issue.
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
car is running. thank you everyone.
i got a crash corse last night on points. we needed to clean the points and pickup it seems like the rotor was not making a solid connection with the cap in the center. so we raised it up a tiny bit to get it to fire. new cap and rotor are ordered. |
One always assumes EVERYONE thinks of the VERY basics when troubleshooting.
Dave |
