what size is the cylinder head temp sensor?
I need to buy a new one and wanted to verify I have the correct socket size to put it on.
Are they 14mm or 13mm?
Thanks!
1987 Porsche 911 Carrera Coupe
Old 09-19-2018, 08:48 AM
Member 911 Anonymous
DRACO A5OG's Avatar
New one is 14MM old single wire 13MM, Yes annoying.
Take a cheap 14MM deep socket and grind a slot in it so you can properly torque the sensor to the head, just be absolutely sure you go in straight and not over torque.
Break a Leg Brother!
'85 Carrera Targa
PCA/POC
Old 09-19-2018, 09:02 AM
Thanks!
CHT Sensor Replacement
Looks like they're 14mm -- see that you reference using a socket to put it on -- keep in mind that the CHT has a wire sticking out of it that will require the use of either an open ended wrench OR a modified socket to put it on.
I used an open ended wrench (actually used a pair of needle nose pliers) to put my new one on, and used a 14 mm socket to remove my old one (snipped its wire off to allow me to use the socket).
Old 09-19-2018, 09:03 AM
thanks all... I wanted to make sure that the new Bosch part available on here was a 14mm.
I am ordering an open split socket and they have the 13mm and 14mm versions available.
Just wanted to make sure I order the right one.
Old 09-19-2018, 09:20 AM
Send a message via Skype™ to kyngfish
Not sure of the dimensions of the open split socket, but check the sensor you bought. Mine had a VERY stiff wire coming off the back of the sensor. I cut a slit into a standard sized deep socket, only to find that it wasn't deep enough and the stiffness of the wire kept pushing the sensor out of alignment in the socket. I didn't want to force it so went another route.
I ended up buying a cheap box wrench in the correct size and just cutting a slit in the closed off end - the open side was too big to fit in the cutout where the sensor goes. I (gently) used that to tighten the sensor down. Took 2 minutes and worked like a charm.
Not to take away from anyone else's excellent advice, that's just what worked for me. I guess it depends on what sensor you got.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 09-19-2018, 09:41 AM
you might want to save your $$$ on the split socket (especially given Kyngfish's guidance on how stiff the wire is) -- the CHT doesn't need to be super-tight, it simply screws into a threaded indentation in the cylinder head. Don't see another foreseeable use for the socket/etc. once installed
Old 09-19-2018, 10:06 AM
DRACO A5OG's Avatar
Well, the idea is to torque to spec and not too over hand tighten. Yes, finger thread it in and use SST at the end for proper torque.
I have seen one too many where the head was damaged due to over tightening, cross threading or peops using JB weld to hold the sensor in place. Kinda a critical to starting so please be mindful of how you install and keep it in place.
Just my humble 2 cents,
J
'85 Carrera Targa
PCA/POC
Old 09-19-2018, 10:16 AM
Did you already order one?
I have a brand new Bosch unit I bought last week, and it turns out i didn't need it after all.
I can give it to you for what I paid, which was cheap.
If this is something you want, message me and I'll send it out today. Cheers!
Old 09-19-2018, 11:02 AM
yes.. already ordered. just waiting for it to arrive.
Old 09-19-2018, 11:35 AM
I may not need to when putting it on... but I have bad luck with everything in life.... and most likely something will happen and I will have to take it back off later on. So best to be prepared for bad luck.
Old 09-19-2018, 11:47 AM
JohnOfTheJungle's Avatar
I took your advice and cut a slot in the closed end of a box wrench. Worked great. Thanks!
Old 10-05-2025, 01:06 PM
