LinkBack | Thread Tools | Rate Thread |
Hardware list available? Nuts bolts washer shopping list for engine etc
Good morning.
I am looking to get some newer plated hardware for my engine rebuild and other various locations around the car. I am not looking for concourse replacements for period correct supplier/year. I am just looking for a shopping list of bolt nut washer sizes/type for an order on Belmetric for example. I have looked at the PET but the information is scattered, if someone has a list they could share that would be terrific. As a side note I saw the kits on Pelican but the reviews were suspect. Thanks in advance. Rob
1979 930 |
Member 911 Anonymous
Mag case or Aluminum?
What ever you get, get the Wrightwood seal kit, everything is there but when it comes to the chain cover make sure the washers are SS as the aluminum ones are worthless and will squash. Also for the engine halves I suggest the all metal lock nuts Use ARP rod bolts/nuts and consider CP Carrillo Pistons or Mahles. Side note, make sure crank shaft is to spec after polishing and straight, case journals are straight and replace oil squirters. Get Porsche Bearings or several OEM but you must measure them to insure they are uniform or place in order of wear on the crank. Break a leg Brother!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thank you for the tips. I have most everything covered on your list but I am just looking for the hardware list regarding sizes of the bolts, nuts washers etc..
Something like this but with the details of the inclusions so I can order from a site like Belmetric https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=show_part_page&make=POR&model=911M§ion=engreb&page=1&bookmark=2&part_number=PEL-REBKT-06
1979 930 |
Red Line Service
Just have all your stuff replated when the parts are at the machine shop. Gold or yellow Cad plating. Most platers charge "by the lot". Average cost in So. Cal is about $80. Send them everything, throttle linkages, clamps, brackets etc. You'll be looking concourse in no time. We also always throw in some extra.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Keep the Shiny Side UP! Pete Z. |
Uncertifiable!!!
+RS O-rings for the rocker pins.
LN Engineering offer some good pistons,rings, etc. as well as piston/cylinder and top end refurbishing services. Talk to Charles. Wurth has an excellent assortment of yellow zinc nuts and bolts. In Canada they deliver; not sure about the US. Good luck. Exilerating project. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
I've never had any luck with plating - even in California. It's pretty much suspect and wears very quickly.
I would replace all hardware from BelMetric. I pretty much used all their stuff on my car and it looks great. No hassle, and it's pretty inexpensive. They ship the same day and it's awesome. |
Thanks.
1979 930 |
Doesn’t pelican offer the fastener “super kit”?
I bought one for my rebuild several years ago. Just what I needed and at a resonable price considering the amazing number of nuts and bolts needed to put this engine back together. |
abides.
I bought some clear plastic organizer cases from harbor freight and filled them with a selection of yellow zinc hardware from Fastenal and other hardware stores. They are also good for organizing hardware during your engine teardown.
You can save a fair amount of money compared to the hardware kits from Belmetric or Pelican.
Graham 1984 Carrera Targa |
