scumbag
has anyone ever run turbo front fenders with SC/Carrera rears?
i was looking at the Guntherwerks 400R and was kind of struck by the fact that the track widths are the same front and rear. it got me thinking, has anyone ever tried something similar on a SC/Carrera? all that would be required is a turbo front and stock rear. ~9" flares all around.
i tried google, but was unable to locate anything any closer in execution than Project Nasty. would it just wildly unbalance the look of the car? i feel like there's a lot of front grip to be gained. if the car doesn't have unlimited HP, there isn't really a need for 13" steamrollers out back. but 245 square would be really gnarly in a light chassis...
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
I've never seen it, but personally I think it would look weird. I think the Gunther car pulls it off because of how wide the car is on both front and rear.
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle Instagram: @pdklol |
I remember this coming up in a thread a while ago. Unfortunately I can't find a link to it. However, I believe most people felt that only having the flared front left the car with an unbalanced look or just something slightly off. Sort of like the uncanny valley but for cars. I'll search a bit more to see if I can't find the thread.
Jonathan '79 Copper 911 SC '88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's |
seen it, looks weird, there was a thread about it a while back with pics
I'd be interested in seeing it too. Seems like the main issue would be the vertical edge of the fenders. On SC/Carrera rear flares, the vertical edge is smaller than on turbo flares. The flat vertical edge on turbo flares gives them a boxier look that wouldn't match the back. Otherwise it sounds pretty cool to me!
Instagram: mossfrog911 1986 911 Coupe in Moss Green Metallic |
(man/dude)
I've often thought that a slight flare on the front of an SC/Carrera would be appropriate, and in fact should have been done at the factory.
I think a front turbo would be a bit much. I'm in the process of having 7" Euromeisters widened to 8" for my front so I can run 225/45-17 tires to match the 255/40-17 on 9" rears. Looking forward to a bit more grip in slow turns when Autocrossing. I'm not anticipating having to flare the fenders to make it work, but might bang/weld something up over the winter to see how it turns out.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
scumbag
i'm thinking of picking up a set of FG turbo flares (cheap) and seeing if they can be modified to give less flare without looking like a trashcan stabbed on a fender.
(man/dude)
STR Carrera: WIDE Front Wheels Part 3 (and new tire brand!) Matt is a user here and has a thread about the car: SCCA STR Autocross Carrera Build He is my inspiration to send my Fakefuchs to Weldcraft for widening to 8". He went to 9" and a 245/40-17 tire which actually worked, as unlikely as it seems. The key of course is the wheel offset. I'm going to play with various spacers but am making other changes (offset balljoints) at the same time. Back to the topic at hand. Project Nasty to me doesn't look like it has any extra width when compared to stock? Maybe a bit more bulge (it does look great!) but no extra clearance. ![]()
scumbag
EDIT: the other thing is that PN's front arches appear to be re-radiused. look at how they are perfect arches with no flattening out like on the car below. that also makes for a lot of room. i have rolled the front fenders on my car. they're very flat. but i'm still some ways away from driving it, so i'm trying to get my best game plan laid out before i get there. i've got those two links open in other tabs right now. i'll check them out.
Yeah I guess it's the 911 ST look, which I think looks great. I'd be curious to see it on an impact bumper car though. I'll let you handle the belt sander on your own car. Post pics!
I would rather be driving
it can work as long as the lip profiles are matched. The edge profile of a 930 flare is highly rounded where the 911SC/Carrera flare has a squared off lip. There are many aesthetic reasons to make this change.
If you want them to match you have to get out the hammer and dolly. 15 years ago you could not buy 911ST flares in steel so I had to make them. ST Project update: roll your own(long with pics) On my current project I am keeping the car narrow body and have changed the profile. Go to post 262 in the link below. Project Minne - A Saga of a 72.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
scumbag
Large Registered Member
I've got 245/45/17's and 275/40/17's on Carrera fenders. It can be done... No need for wide body!!
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Reviving yet another dead post. I only see this as being a positive improvement. It would make the front as wide as the rear would it not? really keen to see pics if possible. Anyone have any leads?
I had planned on going that on my old black SC.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
I’ve seen the combo of Turbo fronts with Carrera rears, and personally am not a fan — the Turbo’s are much more rounded and pronounced, and to me, are too mismatched with the Carrera rears. I have at least one photo in my collection of a few thousand desktop images, if I can find it will post.
One possible solution I’d like to look into one day is something DP makes that you can find on their “Speedy Irishman” — fiberglass (or carbon/kevlar) front fenders with 8" flares.
The 953 (959 Dakar prototype) used 930 front fenders.
(kg/lb) Last edited by Antonov; 01-23-2024 at 10:39 AM.. |
One more...
(kg/lb) |
