redline7500
RSR Rear Quarterpanel fabrication
I am creating a 73 RSR tribute from a donor 1970 race car. Part of the original quarterpanels were removed and fiberglass rear flares were installed with dzeus fasteners. I want to weld in steel quarterpanels and flares to accomodate the 18" rear tires that are 10 inches wide and eliminate the fiberglass quarterpanels. Does anybody know of a good shop in the Atlanta area that is set up to do this kind of work on Porsche's?
Cars and Cappuccino
Carolina Coach Crafters. https://www.carolinacoachcrafters.com/
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
RSR Steel Flares used to be readily available, no?
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
Jon Bingham
thought about shipping it to Denver,Colorado? The Metal Surgeon 3037614884 jon@themetalsurgeon.com i can give you an estimate if interested,thanks |
Real deal steel RSR flares are available from one or two European suppliers. I’ve seen a front and rear set and they are stunning, hand made, and absolutely correct in shape and contour. They are very different than turbo flares. Getting them correctly butt-wielded to the quarter panels is the trick. I’ve done it myself for my car using RS flares and it is *not* easy and I know of know place in Atlanta area that will butt were them, only lap weld which is wrong. If you really want it done right, ship the car to the metal surgeon above.
Science is NOT optional
different contour or what exactly are the differences?
PCA member since 1993 |
They are made in Canada as well. The outer lip on the RSR flare "tends" to be more rounded. Here is a link. They are VERY expensive and currently out of stock.
2.8 RSR Fender flares, set of 4: Restoration Design Inc. |
RSR flare tended to have a more rounded lip. The 930 lip appears to be more square. There are many posts about them. They are made in Canada as well. Currently out of stock, VERY expensive.
Under the radar
Haven't some guys massaged turbo flairs to give the RSR look? I guess it depends on how authentic the OP wants to be.
Jon Bingham
the EU suppliers aren't quite that high, around $4000 shipped would be about right.
No physical quantity completely explains its own existence |
Wish you would......
Marc Zurlinden zurlindengruppe.com |
Jon Bingham
There's a company in the UK that actually has a stamping for them now. 3600 Sterling a set and they are spot on.
Jon, would a fiberglass one work? I might be able to rustle one up.
Jon Bingham
It would,thank you .I could a hammer form from it.Would you know of the origin to research on accuracy feedback.Thank you for the offer. |
Thread Tools | |
Rate This Thread | |
