wierd 78 SC distributor problem.
a mechanic from another shop called me about a car he's been trying to get running right. he said he could turn the dist cap on the dist housing a bit, and the engine ran way better. the initial timing was set at 5° BTDC, as usual, but the response was doggy until he turned the cap. sounds wierd, like the gear was 1/2 tooth off, causing the rotor tip to be quite a bit away from the cap contact, in spite of the timing being set correctly. the mechanical advance is free, the wire plug into the dist is not flipped. i can't think of anything right at this moment. anyone have a thought?
ok, we got it figured out. i suggested he flip the dist wire plug over and that was it. the signal was reversed.
It must suck being that smart huh John ? Cheers.
1969 911E Albert Blue 1970 911E Iris Blue 1970 911T Signal Orange 1972 911T Gold Metallic 1981 930 Arctic Blue 1981 930 BB Auto(on ship) 1987 930 Cassis Red Met 1996 993TT Black 2007 997TT Cobalt 2017 991 Turbo Cab |
Is it indeed possible to reverse the plug?
John, any advice on replacing the distributor wire? I bought the replacement from our host but it has a female connector on the opposite end (away from the distributor). It appears that my wire on the car come directly from the harness. As this is a coax wire, any suggestions on how to splice it in properly or where I can get the male side of the connector? I have a 79SC. GB |
disband
john did the dead CD ever arrive?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
K911, yes the CD arrived. thanks much. i think maybe the dead can pull it together again, given a little time. nothing stays the same.
GB, the coaxial cable on your car needs to have a female plug spliced into it, so the new, double ended green unit can attach. use an ohmmeter before you cut it, to note which side of the plug takes the center signal wire and which is the braided ground. swapping them will cause the above problem. the plug end can be had from a dealer, or use one from an old wire loom. the little crimp on connectors are special too, and require the proper crimp tool to attach them.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-07-2003 at 10:18 AM.. |
Senior Member
Doggonit, John. I thought we had concluded that the polarity of the green wire conductors makes no difference. Now it sounds like it does. Are we talking about the same thing? If the polarity makes a difference, and if I've lost track of which is which, then how can I determine the proper polarity?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Thanks John. I will try to get the part form the dealer.
GB |
