| I would rather be driving Join Date: Apr 2000 Location: Austin, TX
				Need wiring connector: 3.6 distributor Hall Sensor
			I am working on a 3.6 conversion.  The engine wiring harness has a shielded wire that goes to the hall effect sensor on the distributor.  This connector is broken and needs to be repaired.   Does anyone have a source for the 3-pin connector that goes to the distributor pickup? It is not a normal Amp connector. Thanks
				__________________ Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks | ||
|  11-04-2018, 06:55 PM |
			borrowing from a Renn   List...  picture.   I need this wiring harness connector.
|  11-04-2018, 07:08 PM |
| Registered Join Date: Feb 2005 Location: Mexico
			Can you post a picture of the broken connector ? Is it a Tyco junior timer connector ? Something like these?   | ||
|  11-04-2018, 07:18 PM |
			If it is like the one on the right, Pelican sells it https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&description=022+906+233+B Last edited by donporfi; 11-04-2018 at 08:10 PM.. Reason: Harold gave the p/n | ||
|  11-04-2018, 07:22 PM |
|  11-04-2018, 07:28 PM |
| Registered |
			A Porsche 3-pole connector in that style is part number 022 906 233 B.
|  11-04-2018, 07:42 PM |
| Registered Join Date: Mar 2006
			Finjector has great service and postage is cheap. https://www.finjector.com/eng/3_pole_connector_set_for_ign_distributor_incl_term inals_and_b-p-518728-172 You can also call Motec East and talk to Larry. We have bought these from him in the past. | ||
|  11-04-2018, 08:09 PM |
| Registered Join Date: Jul 2001 Location: mt. vernon Wa. USA
			Jamie, contact timmy2 (Dennis Powell). He will be the one that can provide you with the answer. regards, al PS: I've sent you his email address on the Pacwest Slack RG site.....
				__________________ [B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ | ||
|  11-04-2018, 08:57 PM |
| lake wales fla Join Date: Feb 2017
				hall sensor conn.
			a couple of pics of the connector  +1 timmy 2      | ||
|  11-05-2018, 03:23 AM |
			Thanks Everyone.  Going down the path by following your leads... Yes, the connector is the one with the extended Male section and 90 deg knife-edge connector orientation.
|  11-05-2018, 03:49 AM |
			Just FYI.  The connector is Bosch PN 1234485024. Cross reference is VW PN 052905327. With the right Part number there are several sources available. About $15 for the connector, terminals and wire boot.
|  11-05-2018, 08:22 AM |
