Need Headlight switch help
Greetings. Looking for some advice on a headlight switch.
I have an '88 911 which had a headlight switch failure. I purchased the replacement part (91161302904) from Pelican. After reading through my Bentley Service Manual, looked pretty straightforward - simply matching wires with terminals. As I look at the new and old switches, their terminal don't match up. I have 14 wires on my existing switch with only 11 terminals on the new switch. I figured I had ordered the wrong part as my existing part number is 91161302903. Pelican tells me on their site that the switch I was sent is the correct replacement.
In comparison of the new and old switch it appears that I have 2 wires attaching to two separate terminals for wires labeled 58L, 58R and 58. The new switch only has one terminal for each of the two wires. Any advice is appreciated.
Ruxin
Old 11-25-2018, 12:38 PM
proporsche's Avatar
the best help you will get is to take a pic of the new and old switch and post it here
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-25-2018, 12:50 PM
Formerly known as Syzygy
Canada Kev's Avatar
Reference the pin layout here I did when I had issues with my switch. It shows when each terminal is live in relation to the key on or off and which position the headlight is in.
But for a simple comment pertaining to pins 58L and 58R, they are for your parking lights. It looks like your old switch, like mine, used a separate pin for the LEFT and the RIGHT parking lights. If they go to the same pin, 58, it will serve the same function as you can see on the diagram below.
To attach two separate leads to a single terminal pin, there is a small U shaped brass jumper available that will slide into one wire connector on one side of the U-jumper and then the other wire connector will slide over both the other side of the U and the pin on the switch. I hope that makes sense as I don't have any pics. Or you could make your own Y jumper from a couple short wire pieces and some terminal connectors.
Kevin
Old 11-25-2018, 12:51 PM
Headlight switch
Thanks for the information Kevin. I know exactly what you are referring to with the U brass connector. If I can't find them I can make my own. Thanks again for your input.
Ruxin
Old 11-25-2018, 01:41 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Switch.
Here's a bit more help.
A pic from our M/Y 86.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-25-2018, 02:31 PM
sugarwood's Avatar
On my '86, several of the terminals were doubled up.
2 wires would share the same spade with a "fork splitter"
I think my switch only had 9 terminals, but 13 wires.
Turn signal stalk harness
White/black -> 56 (White is the main wire color, black is the stripe color)
Grey/black -> 58L (inside)
Grey/red -> 58R (inside)
Red/white -> 75
Plug Prong harness
Grey/black -> 58L (outside)
Grey/red -> 58R (outside)
Grey solid -> 58 (between 56 & 30)
Grey/white -> N
White/green -> 57
Black/blue -> 58a
Electrical tape wrapped harness
Red/white -> 75
Red solid -> 30
Blue/black & Black/blue -> 58a
1986 Bosch Icon Wipers coupe.
Old 11-25-2018, 03:08 PM
Switch.
Red/white -> 75
Plug Prong harness
Grey/white -> N
White/green -> 57
Black/blue -> 58a
Red/white -> 75
Red solid -> 30
All I can say, is that the switch on our M/Y 86 Targa
is wired as per the above pic, and everything works.
Also, don't forger to pull the + battery cable prior
to working o the switch.
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-26-2018, 07:42 AM
Synchro Joe's Avatar
Some additional info here: 1987 911 headlight wiring issue
Wiring diagrams are available on PP I think, otherwise I have PDF copies and you can PM me.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 11-26-2018, 08:14 AM
