San Diego, CA
Originally Posted by yelcab1 View Post
Want to hear about parts cost?
Each liner on a Ferrari 355 is $1000, it has eight. Head gasket is $500 a piece, it needs 2. Valve job on 40 valves is $4,000. Rings are sold per cylinder at $200 each cylinder. Clutch pack is $2,000. Flywheel runs $4,000. T/O bearing is $600. One set of 16 rod bolts is $1400.
And then you get to pay for the labor.
Word^^^^
Rolls and Bentley are similar. I own one of each.
Pllus for pre- BMW and VW era models, there are only two decent non-dealer parts suppliers and they are located in the UK.
Old 12-05-2018, 07:05 PM
Eva
911SauCy's Avatar
And that's one of those unless you do it every 20k miles the car will lose "value" deals...
Ferarri ownership is for the birds...and with all that required maintenance, arguably the cars are junk
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 12-06-2018, 06:02 AM
Originally Posted by 911SauCy View Post
.....and with all that required maintenance, arguably the cars are junk
Let's not start slinging the mud around. There is plenty coming from Stuttgart.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-06-2018, 07:08 AM
Not to derail the thread, but let's pump the brakes a bit on the above as it's not entirely accurate. Clutch price, machine work and parts cost for the 5v cylinder heads is about spot on though. $4-5k to knock out those heads and guides which were a fundamental issue.
A new piston set with rings can be had for low $2k and the liners can be refurb just like Porsche liners. A full engine gasket set can be had for $800. Main and rod bearings, $1k. Then there's the headers that fail that can be remedied by a seat of stainless at $4-5k. Not for the timid for sure.
No physical quantity completely explains its own existence
Old 12-06-2018, 07:26 AM
Red Line Service
Marc Bixen's Avatar
Here's just one more example of the expense, cam timing, VW, timing gear, cam gear, cam shaft. The same purpose on a 911, over 50 individual part numbers, per side, so that's x2, and that doesn't include the chain housings, covers, cam oil lines etc. 2 parts for a VW, over 100 parts for a 911.
Now cam timing, VW/356, line up one dot between two others, done. 911, dial guages, stands, multiple assemble and dis-assemble operations, minimum, one hour, reality 2-3 hours.
Hope this helps enlighten you to the complexity, and therefore the expense, of repairing a 911 motor.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 12-06-2018, 08:41 AM
