New-ish 911SC Targa Owner
pampadori's Avatar
Velocity stack options for ITBs
I've gone thru a few different setups with my triumph ITB setup.
At first I used some UNI foam filters without a velocity stack under them. This filtered the air but didn't handle lean pops very well - the foam ended up splitting near the flange on 4 of the 6.
Next up I tried these motorcycle v-stacks with metal mesh filter cap on top. Cheap junk. The caps with the mesh kept blowing off.
Moved on to the PMO rain hats and K&N with the weber style stacks. This worked great but the mounting required me to use these things:
If you look closely, they aren't round but oval and add another restriction point before the throttle plates. I can actually feel a difference between the motorcycle stacks (no filter) and the rain hats. Top end felt sluggish with the PMO setup. Disclaimer - the PMO kit is nice and probably doesn't have this issue when used with their carb or ITB kits.
So I'm ready to try something else and would ideally like a velocity stack that has a reliable mesh filter on top. I need the throat to be 52mm or 2". Prefer height to be 3"-6" but not too picky here. I'd also prefer the set of 6 to be somewhere under the $200 it i could.
Anyone got anything similar they could recommend?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 12-12-2018, 08:21 AM
Have you thought about getting a Dremel with a metal cutting bit and reshaping the inside rubber section?
There looks like enough thickness there you could cut it down, reshape it or maybe remove it completely.
Derrick
Old 12-12-2018, 08:30 AM
I would rather be driving
jpnovak's Avatar
Fix the lean pops and you will stop melting the foam. You should not have them.
Old 12-12-2018, 08:34 AM
pampadori's Avatar
Its a fair point. I shouldn't have them. Its only present when cold so I could probably make a few changes and get rid of them easily enough.
The dremel suggestion is a good one. I'll have to go look and see if that would work or not. I recall the kit has an aluminum adapting plate that also has oval holes that might need a mill to round out.
Old 12-12-2018, 08:38 AM
911T '72
DeRRis's Avatar
I’ve seen these on the IB forum. I really like the look.
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 12-12-2018, 10:41 AM
msmall215's Avatar
I used the Triumph throttle boots you have pictured in your first post coupled with the PMO rainhat kit and the Closed Course Motorsports adapter plates. The dremel suggestion the way to go to bore out the boots and you can also take the dremel to the CCM adapter plate to port match everything and create a much better flow path. The other reason for dremeling the boots was to get enough lip for the boots to fit over the throttle bodies.
Mike
'85 3.2C
IG: @msmall90 | @zuffenphilly | @ruchlosrallye
Old 12-12-2018, 11:47 AM
pampadori's Avatar
what is the IB forum? Would love to read more about that...what do you call that? an airbox?
Old 12-12-2018, 12:31 PM
911T '72
DeRRis's Avatar
Impact Bumpers Forum
https://www.impactbumpers.com/forum/index.php?/topic/32160-triumph-itb-conversion/&
Dennis
Old 12-12-2018, 12:51 PM
911T '72
DeRRis's Avatar
SheWee trumpets
Dennis
Old 12-12-2018, 12:54 PM
evan9eleven's Avatar
Here is my solution, for what its worth:
915 rebuild and ITB/EFI project, here we go!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 12-12-2018, 02:46 PM
The "shewee" (that never gets old ) trumpets are mine. Sadly, they don't fit under the lid so I have had to make some different ones. Check out my thread for the details. I have used trumpets from DanSTengineering here in the UK. The adapters would be easy to make so it might give you some ideas for options in the US.
Old 12-12-2018, 03:27 PM
pampadori's Avatar
@evan9eleven that is the perfect solution. Want to cut a couple more of those plates out and mail them to me?!
Old 12-13-2018, 04:47 AM
That's pretty much exactly what I'm planning on doing. I've already sourced a pair of Triumph Tiger/Daytona 955i ITB's, silicone couplers, and hose clamps from Ebay ($167.38 spent so far).
Next I need to buy Clay's manifolds, linkage kit, and fuel rails. (I'm a teacher, so parts accumulation takes some time . )
Pipercross and ITG have blank base plates available for their filter kits that I was thinking about getting.
78 911SC Targa, GP White
Old 12-13-2018, 07:00 AM
Thans guys. I'm happy to provide a drawing of the adapter plates if you want to have some made, but I don't think I'm going to start shipping these from Norway. PM me if you like. As I mentioned in my thread, it was important to me to keep the round bore for as much of the intake tract as possible.
2004 Boxster S
Old 12-13-2018, 12:48 PM
PM sent
Thanks in advance
Old 12-14-2018, 09:55 AM
Nux Nux is offline
Nux's Avatar
Are you looking for suiting trompets for the Triumph ITB's - or just filtration? Or both?
My Triumph ITB from Clay O:
Old 12-14-2018, 10:10 AM
pampadori's Avatar
Hi Nux. I'm looking for both. I think I found a solution combining Evan's plate and welding some 2" tubes to it that protrude enough upward to where i can use my clamp-on velocity stacks inside of the PMO filter/rain hats. The weber compatible stacks aren't exactly the same diameter as the triumph ITbs either so this will allow me to get rid of them too.
I'll try to post a pic here when I finish getting them made.
Old 12-21-2018, 10:19 AM
Nux Nux is offline
Nux's Avatar
I also had difficulties finding stacks for the Triumph ITB's . Got mine custum made from efihardware.com
Old 12-21-2018, 10:48 AM
subscribed and thank you for the ideas guys.
I am looking to upgrade or replace my piper cross filters .looking at IGT filters or individual screens/filters on each stack.
PS KMS Netherlands has a selection of stacks and trumpets.These are what is currently on my 3.6 l setup below(using the piper cross filter plate and KMS stacks and trumpets. )
1979 SC
1986 Carrera 3.6 L+
Old 12-21-2018, 11:11 AM
pampadori's Avatar
I tried my hand at drawing up my design in Tinkercad. Considering I've never messed with this sort of thing before, i found it pretty intuitive and easy to use. Plus, its free so win win.
The tubes are 3" long. Not sure how that will impact the "tune" of the stacks but i think longer is better right? I should be able to still close the engine lid with the rain hats on top.
I plan to use my cheapo velocity stacks on top and then rubber couplers to connect the plate to the throttle bodies.
I'm probably going to have to order a handful of these to reach the shop's minimum order qty so after i get them fitted i might have a few sets available to share. PM me if anyone would like one for cost plus shipping. I'm thinking around $175 for both sides. I'll know for sure once I place the order with the local machine shop.
Old 12-22-2018, 10:09 AM
