Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Intense window cleaner.
Trying to service/understand this system which is not
on the window sticker option list, and never used. As per the attached pic of the my owner's manual, it would appear that the intense washer should activate the secondary washers & wipers by just pressing the switch located under the gauges. When I press the switch "nothing". The pump works when voltage is applied at the pump.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I see the same thing. Maybe the intense fluid reservoir is clogged.
Washers.
Thanks, Gerry
I think you have to have the lights on for the switch to work..
Lights.
Correct, they were on.
Thanks, Gerry
Maybe it's broken.
JUAN '80SC Targa |
It is a separate pump from the windshield pump. At least on my 85 it is. It is really hard to get to to replace. Up behind the bumper and washer bottle.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Pump.
The intensive washer pump is appended to the water
reservoir located near the driver's side front strut. ![]() ^^^^^ Easy access. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 03-05-2019 at 11:03 AM.. |
![]() ^^^^^ So, this is a two step process. 1. Press the switch. 2. Then, turn on the wipers. Right? Gerry
Recreational User
Gerry, yes that's right.
Some of the posters apparently have mistaken the intensive washer system with the headlight washer system. Lights aren't required to be on to use the intensive system. If the pump will activate when fed 12V directly, but not operate when the switch is pressed, then either the switch is faulty or there's an issue with the wiring. |
I don't know this system, but the manual above describes a time limiting relay (guessing like a seat belt warning light timer). That relay check out? I would assume, like the seat belt light, if that relay is shot or missing, no go.
For the switch - I would think you could test to see if switch is bad by popping the clock out, pop the switch out from behind and direct connect/touch the wires..
Scott 1981 911SC Targa - Platinum Metallic Last edited by schoward; 02-16-2019 at 07:56 AM.. |
My car came with the option but the plumbing had been removed by a previous owner. I restored mine last year. Just used the PET guide to order the parts and reconstruct. New parts are available from Pelican/Suncoast. I ordered several bottles of fluid from my local dealer for about $10/bottle. Part number is 000-044-000-93. Works nicely. Be sure your reservoir cap has a good rubber seal. The fluid will evaporate from the reservoir over a day or two if you leave the cap off or have a dried out rubber seal. As mentioned, you don't need the lights to be on.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
Hi Gerry,
Is this absent from your '86 schematic? I do not have the option in the car, but it is shown on my '87 vintage factory schematic. (Zn A15 to C16) There is a power tie between the relay and the wiper motor slip-ring, but I am not sure who is powering whom. The relay is more like a solid state Porsche controller, where the logic isn't readily apparent to me. pls let me know if you need a copy. Dan
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Intensive windshield washer-How it works.
![]() ^^^^^ The 12V for both windshield washer system pumps is provided by fuse #3 block #1. The normal windshield washer relay also has a 12V source from fuse #7 block #2. This source is only for the active/timing circuits, and not the pumps. When the Intense windshield washer system switch is pressed, 12V is passed onto the relay circuitry which closes the relay putting 12V on the pump. So, basically each system requires a low current (for the relay circuits), and, a high current for the pumps. Gerry
Window sticker.
![]() ^^^^^ Also, is there any indication of the "Intense" window washer on our window sticker? Gerry
I see your diode is common to this line as well.
Not even on the options sticker?
Power.
not sure why they did that. Gerry
Links.
As a modest "Thanks" to those who contributed to this thread,
here are two interesting threads. https://www.youtube.com/watch?v=e2RqkUE5Grw https://www.youtube.com/watch?v=-lEsj19bdyM Please share. Best, Gerry
