Flojo's Avatar
Originally Posted by 7783911 View Post
Flojo..idea on when and cost?
not jet. we elaborate the finish... either diamont cut surface ore plain anodized black
Includes bolts to mount?
that's the plan, ready to bolt on.
Maybe even with the needed nut in case some cars dont have it, so you can Weld it in.
will keep my instagram updated
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-05-2019, 11:07 AM
911 enthusiast
tmadden2's Avatar
Following. I’m interested to know more about these jack pads as they develop.
Old 03-05-2019, 11:31 AM
walt's Avatar
Maybe consider making these from Delrin or similar. Very tough material and no post finish required.
Walt
82SC 3.0
81SC 3.6
Old 03-05-2019, 01:49 PM
7783911's Avatar
can some one tell me the bolt size/thread for these mounts?
thanks
Bob
Old 03-07-2019, 12:15 PM
Flojo's Avatar
thanks
Bob
guess its M10 (?)..., just lift the carpet, find the nut and try it out.
Old 03-07-2019, 01:22 PM
7783911's Avatar
if the car was here I would, in shop getting heads done
Old 03-07-2019, 01:36 PM
Flojo's Avatar
Old 03-07-2019, 01:40 PM
7783911's Avatar
thank you
Old 03-07-2019, 02:46 PM
Burnin' Rubber
Koizumi's Avatar
Those custom bolt-on pucks look awesome. I’d sure like a set
Old 03-07-2019, 09:15 PM
Flojo's Avatar
follow me in IG: https://www.instagram.com/spadescustomz_/... soon to come.
Old 03-08-2019, 12:01 AM
I have an 86 911 and I cant seem to locate these 10mm threaded holes.
Can anyone give me some guidance ?
Thank you
Bill
Old 03-12-2019, 02:08 PM
7783911's Avatar
wds, advice given me was lift carpet and you should see the capture nuts...
Old 03-13-2019, 04:51 AM
Thank you , I will follow that advice...
Old 03-13-2019, 01:35 PM
Location: behind the redwood curtain, (humboldt county) california
My 74 seems to have weep holes not threaded bosses
Are there threaded bungs, or inserts that can be welded in to fit these slick lifting pucks, a molly anchor seems kinda light in its absence??
Chris
Old 03-19-2019, 08:19 PM
Uncertifiable!!!
Uwon's Avatar
Chris
Why not use a nut. It’s all covered by loose carpet in the corners.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-20-2019, 05:21 AM
911 enthusiast
tmadden2's Avatar
Originally Posted by Uwon View Post
There are 10mm (check size) threaded holes at each corner of the belly pan, just next to the pinch welds. Get yourself four hockey pucks, drill out the centre, including a recess for the bolt head and screw them in. As I recall, on one corner I also had to saw a slit on the puck as the threaded hole is too close to the pinch weld.
Johan
What do you think the odds are that those threaded holes are a carry-over from attachment points to this kind of overhead crane system on the early 911s?
Old 10-13-2019, 04:58 PM
Vintage Owner
Jack Stands's Avatar
Hockey puck jack points
A few minutes with a Drill press and a Forstner bit and you can fabricate your own. You may find at AC lines may interfere with the attachment points however.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 10-13-2019, 06:09 PM
gduke2010
gduke2010's Avatar
I bought the Esco jack stands from Pelican Parts with the round rubber tops. Quality stands and I bought a pair of axel posts which I use under the solid torsion bar or torsion bar covers. I glued rubber on the posts with contact cement.
Like to put the stands under the torsion bars or torsion bar covers. I have a cabriolet and the door reveal doesn’t change much while on stands .
Old 10-13-2019, 06:15 PM
gduke2010
gduke2010's Avatar
Btw, haven’t seen the screw holes at the jack points. Have a 1985.
Old 10-13-2019, 06:17 PM
Flojo's Avatar
I'm not quite sure but I believe these fixture to vanish around early 3.2s
just drill yours.
Old 10-15-2019, 05:43 AM
