not jet. we elaborate the finish... either diamont cut surface ore plain anodized black
that's the plan, ready to bolt on. Maybe even with the needed nut in case some cars dont have it, so you can Weld it in. will keep my instagram updated
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
911 enthusiast
Following. I’m interested to know more about these jack pads as they develop.
Maybe consider making these from Delrin or similar. Very tough material and no post finish required.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 03-05-2019 at 01:53 PM.. |
can some one tell me the bolt size/thread for these mounts?
thanks Bob |
guess its M10 (?)..., just lift the carpet, find the nut and try it out.
if the car was here I would, in shop getting heads done
thank you
Burnin' Rubber
Those custom bolt-on pucks look awesome. I’d sure like a set
follow me in IG: https://www.instagram.com/spadescustomz_/... soon to come.
I have an 86 911 and I cant seem to locate these 10mm threaded holes.
Can anyone give me some guidance ? Thank you Bill |
wds, advice given me was lift carpet and you should see the capture nuts...
Thank you , I will follow that advice...
Location: behind the redwood curtain, (humboldt county) california
My 74 seems to have weep holes not threaded bosses
Are there threaded bungs, or inserts that can be welded in to fit these slick lifting pucks, a molly anchor seems kinda light in its absence??
Chris |
Uncertifiable!!!
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
911 enthusiast
What do you think the odds are that those threaded holes are a carry-over from attachment points to this kind of overhead crane system on the early 911s?
Vintage Owner
Hockey puck jack points
A few minutes with a Drill press and a Forstner bit and you can fabricate your own. You may find at AC lines may interfere with the attachment points however.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
gduke2010
I bought the Esco jack stands from Pelican Parts with the round rubber tops. Quality stands and I bought a pair of axel posts which I use under the solid torsion bar or torsion bar covers. I glued rubber on the posts with contact cement.
Like to put the stands under the torsion bars or torsion bar covers. I have a cabriolet and the door reveal doesn’t change much while on stands . |
gduke2010
Btw, haven’t seen the screw holes at the jack points. Have a 1985.
just drill yours.
