Jamie79SC's Avatar
Red face Sure glad I didn't need that fire extinguisher I didn't buy last week.
First I noticed that my high beams were stuck on high. Then seconds later– ohmygoshsmoke !!!
After I shut of the ignition, turned of the lights, cursed myself for not buying a fire extinguisher while I was in the speed shop last week, and got ready to disconnect the battery, I checked fuses and relays. Nothing seemed hot or out of place, and the light switch didn’t seem hot either.
Who’s been there done that already and wants to give me the first trouble shooting steps.
Thanks in advance!
Jamie79SC
Old 03-18-2003, 09:34 PM
jyl jyl is online now
jyl's Avatar
Smoke from where?
The high-low beam & turn signal switch (left side of steering column) often goes bad. I guess I would take a look at that. Not too hard to replace, just kind of fiddly.
Old 03-18-2003, 09:44 PM
Jamie79SC's Avatar
Being night, I couldn't see the smoke, only smell it
Jamie79SC
Old 03-18-2003, 09:45 PM
jyl's Avatar
Ah, yes, that would follow.
You can get access to that switch easily by removing the steering wheel and the steering column cover - the "101 Projects" book describes it and maybe there's a tech article on Pelican too. Should be able to see if that's what melted / burned.
The fiddly part is unplugging the old switch's wiring harness under the dash and plugging in the new harness. At least I had a hard time getting my fingers to fit.
Old 03-18-2003, 09:55 PM
Information Junky
island911's Avatar
Yikes!
Yep, all of the current (for the lights) runs through the turn signal/hi-beam switch. Apparently, the contacts wear & fail to carry the needed current.
This is why relay kits were brought to market for our 911s. (read: cheap fix so that the worn stock contacts dont need to carry all the current)
Old 03-18-2003, 09:57 PM
Jamie79SC's Avatar
Yeah, that's probably it. Glen, I'm leaving for Chicago tomorrow morning and won't be back until late Friday night, so it looks like I won't be doing AutoX after all.
Jamie79SC
Old 03-18-2003, 10:11 PM
Silveresrty911S's Avatar
Jamie79SC,
My High/Low/Turn signal stalk went bad a couple of weeks after I bought my car. I asked all the good members on this board and got some good info. You'll need to do a search on "high beams" & "Sucro relay" as there is alot of info for you to read. The biggest problem is the high / low stalk receives full power from the battery to fire up the lights, there for a relay before the power goes to the high / low stalk.
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 03-20-2003, 02:55 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Has something similar in my '67. Puff of smoke, then nothing? Found the culprit months later - one of my dash lights came out and must have grounded somewhere. Burnt the insulation clean off!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 03-20-2003, 04:26 AM
When you drive a 24 years old car, buy a fire extinguisher. You will need it to save your life or someone else's life.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-20-2003, 07:04 AM
