Moronic ignition question
I have an '84 Carrera and an' 89 E30 BMW. Both run off of the Bosch Motronic DME. I've heard that the timing is set electronically by the DME. How does that work as there's a distributor? I can't make sense of it. Thanks
Old 06-01-2019, 06:23 PM
Slow old car
That's not a moronic question
There are several iterations of Bosch Motronic. Earlier versions with a distributor don't have electronic timing, after 1.7, they are set by the DME
https://en.wikipedia.org/wiki/Motronic
Old 06-01-2019, 07:44 PM
911SC Tinkerer
merlinfe's Avatar
Your ‘84 Carreras distributor is fixed. There is no adjusting it. There are also no fly weights in it. Your timed spark events (advance and retard) are controlled by the ECU. Your E30 is the same (provided it has the stock M20 engine). Find yourself a decent set of literature on EFI. It’s worth the read for car people.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 06-01-2019, 07:58 PM
Originally Posted by merlinfe View Post
….There are also no fly weights in it. .
-Steve
I think there is:
3.2 distributor rebuild
Old 06-01-2019, 09:12 PM
-Steve
Agreed, nothing is adjustable. There is advance weights and springs in the Porsche. Knowing that the coil is feeding the distributor and the distributor is mechanically spinning and distributing the spark, how can the ECU possibly be controlling the spark timing?
Old 06-02-2019, 03:35 AM
Diss Member
Quicksilver's Avatar
I think there is:
There are fly weights in the distributor.
And they do nothing to adjust the ignition timing.
The distributor fly weights are there to keep the contact on the rotor pointed at the contacts in the distributor at higher RPMs when the engine is running more advance.
The coil fires when the DME triggers it. That is your timing. The DME looks at the sensor readings and uses that information to look up the data from a table on its ROM (the "chip"). That is 100% of how the timing is controlled in the Motronic 3.2 Carrera.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-02-2019, 04:21 AM
There is a TDC or RPM sensor at the flywheel. It tells the DME where Z1 is, and from there the DME figures out where top dead center is for each cylinder. Then it is just a matter of firing the ignition at TDC, before TDC, or After TDC and by how many degrees. There is no adjustment at the distributor. End.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-02-2019, 08:15 AM
Think of it like coil on plug except with only one coil and a distributor. The DME does the rest.
Old 06-04-2019, 06:12 AM
I didn't realize that the coil wasn't 'hot' all the time and that the DME triggers the coil for each cylinder. That explains how it controls spark. Combined with the large "contact" area of the rotor it allows for the DME to advance and retard timing
Old 06-04-2019, 06:18 AM
Bill Verburg's Avatar
TDC is determined by the 60-2 tooth flywheel(2 teeth are missing and that marks TDC),There are 2 inductive sensors that monitor the teeth, 1 is a reference sensor to find TDC the other a speed sensor.
the fly weights in the distributor are for phasing, ie keeping the rotor aligned w/ the proper cylinder contact at all rpm
Bill Verburg
Old 06-04-2019, 07:18 AM
Yea, what Bill said.
You can hang your timing light on the wall for display only next to the dwell meter and oil can opener-spout like I have.
Old 06-04-2019, 07:22 AM
