Which oil should I use for my 3.2?
Will only drive it in spring/summer/fall, I drive in spirited manner but no tracking. Only drive it on the weekend so cost is less of an issue. Thank you in advance!
Jonas
Old 05-26-2019, 07:03 AM
Vulnerari Praesidio
Valvoline VR1 20W-50
You could try the search function...
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 05-26-2019, 07:24 AM
HarryD's Avatar
A high quality 20W-50 with a high level of ZDDP. Valvoline VR1, Penn Grade, Kendal Gt2 are are common recommendations.
While it can be overwhelming, read the many threads on the topic.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-26-2019, 08:01 AM
I run 15/50 Mobil 1 in my SC, mostly because it's so affordable at Walmart and has high ZDDP. I'd likely be just as well off running Delo or just about any other modern oil. We all obsess way too much on this. I do buy Mahle filters....don't go cheap on those. Best, John
Old 05-26-2019, 08:12 AM
Porsche A40 approved oils in 0w 40 M1 for me.
Old 05-26-2019, 09:56 AM
Brew Master
cabmandone's Avatar
Can of worms opened.
Right now it has Castrol in it. I typically buy Havoline 20w50 but the place I normally get it was out. I have no preference to brand.
Nick
Old 05-26-2019, 02:52 PM
Bill Verburg's Avatar
Jonas
Your car was originally spec'f for a 15w-50 or 15w-40 oil w/ ZDDP levels in the 1100 to 1300 ppm range
there are several oils available that fit the bill
If a particular oil company refuses to provide ZDDP levels I'd avoid their products
Mobil is widely available and reasonably priced, here is the Mobil 2019 spec sheet, remember you are looking for 15w40 or 15w-50 and Phosphorus and Zinc levels in in the 1100 to 1300 ppm range, anything outside those values is not what was originally spec'f and the further out the worse for the motor longevity.
Bill Verburg
Old 05-26-2019, 04:02 PM
HarryD's Avatar
Bill:
Looking at my Bentley, 20W-50 is recommended for 15 F to 100F+
Harry
2020 MB E350 4Matic
Old 05-26-2019, 04:45 PM
Originally Posted by HarryD View Post
Bill:
"API SE or SF 10w/50, 15w/40, or 20w50 For all year operation Latter oil not for temperature below -15C"
SF became the spec in 1988 ZDDP for that and SE was ~1100/1400
generally these were non synthetic back in that era. Porsche latter codified it and specified
mineral oil
15w-40, 20w-50 for temps mostly above 50F/10C
synthetic oil
10w-40, 15w-40, 15w-50 for temps mostly above 50F/10C
other specs for lower temps of course,
This is all in the TSBs from the era
Bill Verburg
Old 05-26-2019, 05:39 PM
The first 3 years I owned this 3.2 I used Brad Penn 20W50 with an oil consumption of 1200miles/qt. Next I switched to Valvoline VR1 20W50 and consumption dropped to about 1750miles/qt. This year switching to Liqui Moly Touring High Tech 20W50 and having driven about 600 miles I do not see any appreciable oil usage, even though as miles build up it is natural to expect some oil consumption, but no doubt this reduction is notable. And the engine purrs beautifully!
I also use Liqui Moly MoS2, but I used that along with the previous oil brands.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 05-26-2019, 06:29 PM
OCPO
Storage Man's Avatar
This could get ugly. BP 15w40 but I tend to top off with BP 20w50.... please check this out. Many questions will be answered...
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
2006 530xi BillyBoat/H&R's....gone
Old 05-27-2019, 05:35 AM
shawn908's Avatar
FYI - here is one where there is a specific pitch on the website for use in air cooled Porsche engines. FWIW this product was recommended by a Porsche shop about 40 miles from Philly when the local PCA club held a meeting at the shop. I've been drinking the Brad Penn koolaid...so no direct experience with Joe Gibbs.
https://lnengineering.com/joe-gibbs-racing-dt50-full-synthetic-15w50-aircooled-engine-oil-12-quarts.html
Old 05-27-2019, 06:40 AM
HarryD's Avatar
The Joe Gibbs product seems to be very good. That said, I have been using BP almost since I got my car in 2002. I had to get a top end done to my car about 1-2 years ago with 160,000 miles. when the motor was apart, other than the damage to my piton and head due to a screw getting into it, the internals looked excellent and minimal evidence of wear. To me, anyway, BP 20W-50 looks to be the correct product for my use.
Harry
2020 MB E350 4Matic
Old 05-27-2019, 07:18 AM
DWeg1998's Avatar
I don’t know that I have ever read on here someone saying that their engine when apart was showing excessive wear and issues that pointed to use of inferior oil product selection.
If you keep it clean with appropriate change intervals and use proper weight with any API certified oil, I have to think you are going to be alright for a road car.
Old 05-27-2019, 09:49 AM
Mostly because almost everyone is using a decent oil.
The problems beagan back in the early 2000s when there was a switch in some oils to less than a 1000ppm ZDDP, it's now common is some oils to have 800ppm or less. Thes oils don't provide proper wear characteristics on the cam lobes. I know one fellow that trashed his 964 after just a year or so of using such oil.
Use the right weight and right ZDDP content and the car will be happy, there are several very good oils out there and also some marginal ones. Just avoid the sub 1000 ppm ZDDP oils by doing your due diligence
Bill Verburg
Old 05-27-2019, 10:14 AM
HarryD's Avatar
Bill, Well said. Exactly the point. Our flat tappet engines require a bit of extra due diligence. One can always read this foolish thread for some older wisdom: forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html
Harry
2020 MB E350 4Matic
Old 05-27-2019, 10:57 AM
Bill Douglas's Avatar
Yes, reputable brand, good ZDDP, replace it more often than specified. And don't thrash the car when it's cold. This advice leads to a long and happy life for a 911 engine.
Old 05-27-2019, 12:56 PM
There are substitutes for ZDDP... In Germany no one uses Brad Penn or Valvoline...
Old 05-27-2019, 02:36 PM
Cars and Cappuccino
tdw28210's Avatar
Like this soon-to-be-hitting-US-shelves Liqui-Moly Klassic
https://www.liqui-moly.com/en/company/news/detail/news/classic-car-care-fountain-of-youth-for-your-favorite-1717-1.html
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 05-27-2019, 03:00 PM
HarryD's Avatar
True but they are not available here at a reasonable price.
Harry
2020 MB E350 4Matic
Old 05-27-2019, 03:29 PM
