rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Lighting connection question
I recently had my front bumper removed and painted. After picking the car up, I noticed that my right fog light and the right side marker lights don't work, though the right front turn signal does work. Is this most likely an unattached connector, or in such a case, would all 3 right front lights fail to operate? If it is a bad connection, where would I look first? The wires seem to go inside a body panel. I tried swapping the working left side marker bulb with the right, but that didn't fix it.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 06-01-2019, 01:45 PM
ROW '78 911 Targa
timmy2's Avatar
Connectors are under/behind the bumper and in the headlight bucket. If headlight wasn’t removed, then likely not connected behind the bumper.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-01-2019, 02:50 PM
rs6er's Avatar
Don't believe headlight was removed. Wouldn't be surprised if this so-called reputable Oregon restorer failed to connect it. Other finishing details were shoddy as well. Thanks. I'll try looking.
John
Old 06-01-2019, 03:35 PM
ROW '78 911 Targa
timmy2's Avatar
They are a bear to get to. Likely why they may not have been reconnected.
Dennis
Old 06-01-2019, 04:40 PM
rs6er's Avatar
That’s what I was afraid of.
John
Old 06-01-2019, 05:05 PM
