997.2 battery jumper post doesn’t open frunk
Battery is dead so I connected jump to the fuse box jumper post to open the frunk. I could tell that certain other accessories were being powered,however, the frunk latch was still not activating. I got the frunk open after pulling the wheel and tugging on the emergency release cable (pita)😤. The frunk fuse was OK. Any others have this problem or any suggestions? Is there a wiring diagram showing the accessories that are powered by the fuse panel jumper post?
I had the exact same problem.
Sorry, don't recall definitely what made it open. I think I had to turn the key to 'run' and then try. Strange.
07 911 Turbo - Pilot Sport Cup 2 ZP 96 Carrera 4 - Toyo R888r 73 911E - Hoosier R7 + twin 75's 92 Corvette - Nitto NT01 14 BMW X3 - Pilot Sport A/S 4 |
Red Line Service
Make sure you have a good ground. Try the door latch chrome loop.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Insert Tag Line HERE.....
Battery jumper wont do it. Has to be a battery or jumper cables.. Never thought to figure out why that is, but it is what it is..
Marc |
Grappler
There should be a cable near the front wheel. Here's a pic of a Boxster but it should be very close.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
It works this way:
1) 9V battery or larger connected to the fuse panel battery contacts. 2) Open the front trunk with your key remote. (Note: it is in the Owners Manual).
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl |
