LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Replacing clock with GPS Speedometer
Hi,
Bought this on Ebay. 85mm GPS Speedo. Cost approximately 80 dollars Australian (which in US dollars means very little). A little bit of silicon tape in place of rubber around the clock and a perfect fit. Three wires to connect (Positive, Negative, and one for instrument lights). A straight swap for the clock. A 15min job.
An addition will be a switch on the positive as it always on to be able to turn the GPS Speedo off when car is parked. Then the trip odometer would zero. Something to cut down the glare would be good too
Button on back allows for KPH or MPH.
Can also see in picture a laser-printed speedo face. Mine was too cluttered showing both scales
Old 06-16-2019, 03:55 AM
I like it, pretty slick.
Old 06-16-2019, 12:43 PM
Bill Douglas's Avatar
I like it. You did a good job on the original speedo.
Old 06-16-2019, 01:34 PM
sugarwood's Avatar
I only look at the giant gauge in the center.
And the drunk press once in a while
1986 Bosch Icon Wipers coupe.
Old 06-16-2019, 02:13 PM
speedracer92's Avatar
Cool. You have the brand name? Didn't see it on eBay.
Old 06-16-2019, 04:24 PM
thanks Bill for the compliment.
It is a laser printed on standard paper with a paper sealer painted over it. Hopefully it lasts.
I would rather use the old speedo but like the GPS speedo there as well.
I did a search for 300km GPS speedometer on ebay.com and found it. Make sure you get the one with the black bezel.
Old 06-16-2019, 07:49 PM
911tracker85's Avatar
I plan to install a GPS speedo in my project. it originally had a mechanical drive speedo and older 915 gearbox.
I now have a short bell housing 930 gearbox. but depending on tires, gearing, etc had concerns about being able to calibrate an elec or mech drive speedo.
I want to mount in the location of the speedo and a AFR/boost gauge in the clock position.
thanks for the post.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 06-17-2019, 05:16 AM
Cool idea. I did a GPS sensor to my stock speedo, and kept my clock.
I have a 3D printer/laser engraver. Would love to know how you made a Speedo face with a laser. Hmmm.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 06-17-2019, 08:55 AM
safe's Avatar
Cool ! I was thinking this weekend on how great a thing like this would be instead of the non working clock.
There is several versions is see.
https://www.ebay.co.uk/itm/272788047553
Magnus
Old 06-17-2019, 10:04 AM
Do you have details on this? I have a '77 with a 3.2 swap and my speedo does not work.
Old 06-17-2019, 10:50 AM
I would rather be driving
jpnovak's Avatar
Just follow the lead...
search 85mm GPS speedometer on eBay. tons of listings.
Old 06-17-2019, 11:02 AM
https://www.speedhut.com/gauges/
Old 06-17-2019, 01:49 PM
sugarwood's Avatar
I think you can get the clock repaired for a small fee.
Old 06-18-2019, 06:25 AM
Go to amazon a search for an auto meter gps speedometer sensor. I have also posted a link here before in other threads.
Old 06-19-2019, 12:20 AM
